Picked up this beauty this weekend!!!
#2655467
05/14/19 06:31 PM
05/14/19 06:31 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Picked up this one family owned 72 Powerwagon Saturday. Needs some attention here and there but its basic stuff, brakes, tires, etc but overall its pretty solid. It's been sitting since 02, had to drain the rotten gas, put a battery in it and it started right up and ran fine. Engine is a 360 with a "granny" 4 speed, 3.55 gears. I have lots of questions about the uniqueness of the 72 since it was a year one style, the plastic dash is toast, going to need a new one, rear is an 8 3/4, front looks like a small Dana? Only rust is in the rear down legs of both fenders. So step in 72 powerwagon experts...what have I got here? Any tips of stuff I should look out for? ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: Picked up this beauty this weekend!!!
[Re: larrymopar360]
#2655522
05/14/19 08:50 PM
05/14/19 08:50 PM
RapidusMaximus
Weatherford, Texas
It seems oddly optioned, manual steering, no air, 4 speed am radio...and power brakes? I don't see wheel covers on the underhood sticker does that mean it didn't come with them?
[Re: RapidusMaximus]
#2655530
05/14/19 09:17 PM
05/14/19 09:17 PM
Posts: 206 Paducah, KY USA Earth
jcruse64
Nice one!!!! My favorite grille. 72 and 73 very similar; same grille, same interior, etc. 74 has same interior also, (edit) including dash, but change in grille (74-76 same grille). 74 is last of the 205 TC and part time 4WD, until 1980, in trucks.
#2655542
05/14/19 09:47 PM
05/14/19 09:47 PM
Posts: 738 Middle TN.
4x4 Roundup
Middle TN.
It seems oddly optioned, manual steering, no air, 4 speed am radio...and power brakes? I don't see wheel covers on the underhood sticker does that mean it didn't come with them? Not that oddly optioned, it was ordered to be worked. My Father ordered one exactly like that in '72 except it was dark blue/white combo. with med. blue interior w/318. I think the power brakes were std. And no they did not come with wheel covers std. , even on the Adventurer. His came with off white steel wheels. Congrats on the Truck. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
WANTED-- DEAD or ALIVE: '70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car. '79 Power Wagon W14JE9S137761 or 763
[Re: basketcase]
#2655598
05/15/19 05:32 AM
05/15/19 05:32 AM
RapidusMaximus
Weatherford, Texas
Thanks for the comments guys, my plans for the weekend are to flush the gas tank and radiator, change the oil/filter, new fuel filters and try to run it long enough to quiet one REALLY noisy lifter then get it moved from the driveway into the shop where the next deal will be to get the locking lug nuts off all four wheels (yep, owner lost the key)...once I get the wheels off then it looks like it will be a complete overhaul of the brakes...currently the brake pedal sticks on the floor ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) On a side note...what's the feasibility of converting the front drums to disc?
[Re: basketcase]
#2655625
05/15/19 09:20 AM
05/15/19 09:20 AM
Posts: 1,849 South Bend
John Brown
South Bend
If the lug nuts are the round bulged out in the middle kind, pound a too small socket over them and take them off with a breaker bar. When that won't work, I have broken the stud off and then replaced one on each wheel.
#2655628
05/15/19 09:21 AM
05/15/19 09:21 AM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
My 74 crew was converted to discs using the pieces off I believe a mid 70's to mid 80's Chevy truck. Everything from the knuckles out, maybe even the stub axles and I'm not sure if you really need the knuckles. So much of that basic Dana 44 stuff is the same between the two.
[Re: Guitar Jones]
#2655738
05/15/19 04:32 PM
05/15/19 04:32 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
My 74 crew was converted to discs using the pieces off I believe a mid 70's to mid 80's Chevy truck. Everything from the knuckles out, maybe even the stub axles and I'm not sure if you really need the knuckles. So much of that basic Dana 44 stuff is the same between the two. The only problem is this is a 1/2 ton. The Chevy will have 6 lugs.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Soopernaut]
#2655815
05/15/19 08:46 PM
05/15/19 08:46 PM
RapidusMaximus
Weatherford, Texas
Got a little more done today, toasted dash pad is removed, greased every zerk I could find, changed oil and filter, fuel filters, master cylinder and alternator had to come out of Dallas so didn't get those until late, should have it almost ready for a test drive if I can get those blasted locking lug nuts off, bought a tool at Orielly's that was supposed to work but the nuts were to large in diameter for the tool to fit. Tomorrow I'll weld a lug nut on to the lock nut and see if that works, so far air chisel and small pipe wrench have both failed. Sure wish someone would pipe in with a disc brake swap grand plan...lol ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: 4x4 Roundup]
#2655898
05/16/19 05:43 AM
05/16/19 05:43 AM
RapidusMaximus
Weatherford, Texas
Got a little more done today, toasted dash pad is removed, greased every zerk I could find, changed oil and filter, fuel filters, master cylinder and alternator had to come out of Dallas so didn't get those until late, should have it almost ready for a test drive if I can get those blasted locking lug nuts off, bought a tool at Orielly's that was supposed to work but the nuts were to large in diameter for the tool to fit. Tomorrow I'll weld a lug nut on to the lock nut and see if that works, so far air chisel and small pipe wrench have both failed. Sure wish someone would pipe in with a disc brake swap grand plan...lol I have been told that front discs were a little known option in '74 which would be the same axle as the '72. I've been googling my tail off from every direction I can think of and Ford stuff keeps popping up ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: 4x4 Roundup]
#2655948
05/16/19 09:39 AM
05/16/19 09:39 AM
Soopernaut
Des Moines IA
I have been told that front discs were a little known option in '74 which would be the same axle as the '72. The only 74 4 wheel drive Dodge with discs was the Ramcharger, which used a different version of the Dana 44 (75-79 truck version). You'll have to find an 80-84 1/2 ton to get the same bolt pattern with discs and lockouts, or 85-93 with a center axle disconnect. I do not know if the parts will swap over to your axle, but I recall hearing they do.
#2656107
05/16/19 08:25 PM
05/16/19 08:25 PM
RapidusMaximus
Weatherford, Texas
Is it normal for both front and rear diffs to be single track?
#2656123
05/16/19 09:13 PM
05/16/19 09:13 PM
4x4 Roundup
Middle TN.
Is it normal for both front and rear diffs to be single track? Yes. Limited slip aka anti-spin was available as an option on the rear only. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
