Intermittent cranking issue #2655464
05/14/19 06:24 PM
05/14/19 06:24 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
I am having an intermittent cranking issue on my 66 Belvedere. Every now and then when I turn the key the starter relay will click, but the starter will not turn. I have replaced the starter relay and the starter, the issue has not changed. I have verified the relay is getting ground from the NSS, and power from the IGN wire, and the starter relay clicks every time I turn the key, provided it isn’t in gear. The starter relay is sending 12v to the solenoid, and the wire has good continuity going down to the solenoid.
I did notice that both the new (95 ram) and old (MP mini) starters have continuity between the solenoid post and the starter housing. Is this normal?
Anything else I can diagnose? Any ideas would be greatly appreciated.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Intermittent cranking issue [Re: OUTLAWD] #2655509
05/14/19 08:29 PM
05/14/19 08:29 PM
Quote
confirm the ground path is good: "battery neg to frame" in addition to the std batt neg cable to block.
Re: Intermittent cranking issue [Re: RapidRobert] #2655524
05/14/19 08:50 PM
05/14/19 08:50 PM
Andrewh Offline
Andrewh  Offline
last time I had that problem the ground to the battery to block was bad.
obviously still showed continuity, but couldn't carry the amps.
It got so bad eventually I couldn't crank at all. I found that I bent the cable at the block end and I could start temporarlily and get it replaced.
Re: Intermittent cranking issue [Re: Andrewh] #2655597
05/15/19 05:29 AM
05/15/19 05:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The starter disc inside connecting the main terminal to the armature may be worn. Kits are available to replace them. Do a voltage drop test. Positive battery to positive post of the starter. then try to crank. Volt meter should read less than 1 volt. Also test the ground side negative battery post to starter case. should b the same result. If so pull the starter apart and check the disc.
https://www.amazon.com/Starter-Solenoid-Starters-Chrysler-Plymouth-x/dp/B008U80X5G
Doug
Re: Intermittent cranking issue [Re: dvw] #2655655
05/15/19 10:51 AM
05/15/19 10:51 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I ending up grounding my starter relay to get mine to not do what your is doing... twocents
...FAFO...
Re: Intermittent cranking issue [Re: skicker] #2656016
05/16/19 01:36 PM
05/16/19 01:36 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
Thanks all,
I'll try to get out in the shop tonight and verify all the grounds and perform a couple tests
Re: Intermittent cranking issue [Re: skicker] #2656030
05/16/19 02:51 PM
05/16/19 02:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
[quote=skicker] outI ending up grounding my starter relay to get mine to not do what your is doing... twocents [/quotestarter relay only needs to be grounded with manual trans w/o clutch switch. Auto grounds through the neutral safety switch. If it clicks, it's seeing ground.
Doug
Re: Intermittent cranking issue [Re: dvw] #2656041
05/16/19 03:42 PM
05/16/19 03:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had the intermittent start issue on 3 different cars over the last 30 years:
1. Baked direct-drive starter on Hemi with headers; might click & not spin starter, might click & turn over.
Adding heat shield on rebuild of starter fixed that, then I got a Robb MC starter and really fixed it.
2. Faulty ignition switch, same symptoms as above
Replaced switch.
3. Loose post on starter relay, either no click or would start; wiggle post = start.
Replaced relay. (4-speed car, no NSS to confuse matters)
Re: Intermittent cranking issue [Re: topside] #2656188
05/17/19 08:17 AM
05/17/19 08:17 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
dvw...
I had used a 68 Charger 8 3/4 rear and transmission I had from a parts car.
When the 70 Satellite was put together I wasn't aware of the difference between the NSS switches.
The comb in the valve body is wrong for the 3 pin NSS I put in the transmission once I found the 3 pin connector while hooking everything up.
The early comb in the valve body with the 3 pin NSS made the back-up lights stay on in D-2-1.
I wired them through the Aftermarket floor shifter and didn't worry too much about it...
At some point I'll have to correct everything if I ever have to pull the transmission...
In the end I could just have a bad relay... shruggy
It still does it in about 1 in 20 or so start ups... flame
...FAFO...
