Lowering 2005 ram 2500 4X4 #2655084
05/13/19 06:19 PM
05/13/19 06:19 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So I have an 05 hemi 2500 4x4 and hate climing in and out of it to put cylinder heads and things in and out of the bed and my pee pee is not so small that I need a truck 47 feet in the air, can I just pull those silly factory spacers out of the rear leaf spring packs to lower it an inch or two? What about the front, what is the best way to lower it a little to match?
Re: Lowering 2005 ram 2500 4X4 [Re: HotRodDave] #2655295
05/14/19 10:47 AM
05/14/19 10:47 AM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
Yeah you can on the back. I did on my 06 3500. The front, not so sure. Might have to try a few different springs. I know there are a fair amount of diesel drag trucks that are 4wd and lowered might want to try and see what they did. You can always cut a coil out of it.
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Lowering 2005 ram 2500 4X4 [Re: Jambbii] #2655682
05/15/19 12:43 PM
05/15/19 12:43 PM
Kalispell Mt.
Kalispell Mt.
No idea on the front? What about a pair from say a hemi regular cab 3/4 ton? Would they let my 4 door set just a little lower or are they the same rate and length?
Re: Lowering 2005 ram 2500 4X4 [Re: Jambbii] #2656147
05/16/19 10:45 PM
05/16/19 10:45 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Can you post a pic so I can see the ride height?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
