Best thread sealant for fuel fittings.
#2654125
05/10/19 07:12 PM
05/10/19 07:12 PM
Posts: 1,183 clarks summit pa
73cuda340
clarks summit pa
What seems to be the best sealant for sealing fuel fittings? I've read good things about the Permatex Aviation Form-A-Gasket No. 3 Sealant. Are there any better options out there? The fittings on my fuel pressure regulator have a tiny leak and I need to seal them up before something catches on fire.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Best thread sealant for fuel fittings.
[Re: 73cuda340]
#2654206
05/10/19 11:27 PM
05/10/19 11:27 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Fuel fittings shouldn't need any type of sealant, they all are metal to metal crush type 45 degree seals. If they are tight enough they seal....Otherwise on hose to line connections double up the hose clamps if you want to be extra safe.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2654217
05/11/19 12:46 AM
05/11/19 12:46 AM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
Fuel fittings shouldn't need any type of sealant, they all are metal to metal crush type 45 degree seals. If they are tight enough they seal....Otherwise on hose to line connections double up the hose clamps if you want to be extra safe. Like he sez...no sealant. Its a metal-to-metal situation. You maybe able to glue together low pressure liquid or gaseous connections and prevent a leak, Try that with 3,000psi aircraft hydraulic systems? or, even your wife's gas clothes dryer...read the install instruction...NO sealer/glue/compound/etc. on the flare fitting.
[Re: 6PakBee]
#2654441
05/11/19 10:16 PM
05/11/19 10:16 PM
73cuda340
clarks summit pa
I have one of the Holley Hp billet regulators with NPT fittings, so no flare fittings.
[Re: 73cuda340]
#2654534
05/12/19 10:43 AM
05/12/19 10:43 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
I must be OLD! I still have a few rolls of teflon tape............ Most of my fitting these days are AN.
