Re: hump welding
[Re: Stanton]
#2651741
05/03/19 09:26 PM
05/03/19 09:26 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
They were spot welded. Seam sealer was used around the joint. On my 68 and 69 Road Runners they are stitch welded, one inch or so of weld ever 6 or so inches around the perimeter. Seam sealer gobbed all around the hump from the inside basically covering the lapped metal. No seam sealer from underside. Though, if not concours correct, wouldn't be a bad idea.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: hump welding
[Re: johnfin]
#2653284
05/08/19 08:18 AM
05/08/19 08:18 AM
RoadRunner
i would think if it didnt follow the hump profile there would be a pocket for dirt to get trapped. Yep it can trap dirt and moisture. The hole stamped in the floor pan for the four speed cars is smaller than the outside flange of the hump. If you place the hump on the pan, it will drop right into place. Take a sharpie marker and trace around the outside of the flange. I removed a hump from a parts car (back before there were reproductions) and the measurements I took were something like 1" from outside flange up towards the firewall and back by lower end of hole next to the seat. The rest (flat floor area and top of hump seemed to be about 1-1/4" to 1-1/2" away from outside flange. To make sure you have enough space, I'd go with the 1". The rods up at the front get pretty close to the floor. Here is a worms eye view looking up at shifter. You can see floor pan is close to rods. I actually shipped paint when installing the assembled trans when I restored the car. I now pull shifter and linkage. Where the paint is chipped is a little shelf of the floor pan. Could probably place a dime or so up there. It should have been cut a bit more. The donor hump came from a rusted floor pan so was hard to get good measurements. From the factory all this work was done as the body was being assembled and the whole thing got dipped and primed. So the potential to rust was about the same as other places on the body.
Re: hump welding
[Re: 70HemiGTX]
#2658582
05/23/19 10:08 PM
05/23/19 10:08 PM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
That's how the hump is welded into my 70 GTX. [/quote] Same for the hump I pirated out of a '70 Roadrunner
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
