Re: Medium Blue in a can?
[Re: JAMESDART]
#2649658
04/27/19 08:29 PM
04/27/19 08:29 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
I'm in the same boat looking for the suede paint in a color for my steering column. It's actually pretty tough to find it. One vendor Instrument Specialties has the OE PPG Duracryl Lacquer for $250/pint in a color. 'spensive pint 'o paintMopaint which is now Kolor Korrect used to sell it in spray cans and it says they have it available on their webpage but when I inquired about it recently they told me it was no longer available. Year One sells the (mostly) correct colors but it does not have the texture in it. If you can find it locally I believe SEM makes some type of textured clear in a can though it may not match the OE suede.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2649664
04/27/19 09:05 PM
04/27/19 09:05 PM
Posts: 2,364 PA
70HemiGTX
PA
[Re: RMCHRGR]
#2649685
04/27/19 09:47 PM
04/27/19 09:47 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I'm in the same boat looking for the suede paint in a color for my steering column. It's actually pretty tough to find it. One vendor Instrument Specialties has the OE PPG Duracryl Lacquer for $250/pint in a color. 'spensive pint 'o paint Five years ago that paint was $100 - the ingredient to make it is going away. Better get it while you can.
[Re: Morty426]
#2649691
04/27/19 10:02 PM
04/27/19 10:02 PM
RMCHRGR
Spahn Ranch
I have never heard of anyone putting the correct suede paint in a can. About 10-12 years ago, I bought a can of it from Mopaint for my old '71 B5 blue Dart with a blue interior, probably the same thing that Andy is looking for. It was dead nuts.
[Re: Morty426]
#2649694
04/27/19 10:04 PM
04/27/19 10:04 PM
RMCHRGR
Spahn Ranch
Five years ago that paint was $100 - the ingredient to make it is going away. Better get it while you can. What is the ingredient, like a mica or something? Even though it's dull there is a slight metallic quality to it.
[Re: AndyF]
#2649696
04/27/19 10:08 PM
04/27/19 10:08 PM
RMCHRGR
Spahn Ranch
I don't really care about having the correct finish, I'd just like the correct color. It is a race car not a show car. I'd think I'd could find B5 in a spray can somewhere. I've looked at most of the usual suspects so far and I don't see anyone selling the classic colors in a can. Try Year One. I recently bought a few cans from them, the colors are close enough for horseshoes or hand grenades. It's good to have the textured paint on the column though, cuts down on reflective glare.
[Re: AndyF]
#2649746
04/28/19 07:10 AM
04/28/19 07:10 AM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Try here, Andy- www.paintscratch.comFound it when I was looking for the correct color to paint the model of my first car. Touch-up, spray cans, pints, etc.... Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2650359
04/29/19 09:11 PM
04/29/19 09:11 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
If the color is represented in a swatch/chip, it could be mixed and loaded in a can. Have had this done before. Most paint shops can do this.
383, Hemi 4-Speed, AlterKtion, D60
[Re: I_bleed_MOPAR]
#2650379
04/29/19 10:11 PM
04/29/19 10:11 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Try here, Andy- www.paintscratch.comFound it when I was looking for the correct color to paint the model of my first car. Touch-up, spray cans, pints, etc.... Tim Thanks for their link Tim! I think I'll send them a part with my 64 Belvedere's light blue and get a metal single stage kit & a kit for the interior. I always had a local paint store match my colors & put them in a spray can. Worked well, but was $75 per can for paint alone. Andy could always see if a local paint store could mix a can of B5 matched to a part sample if he has one.
[Re: AndyF]
#2650397
04/29/19 10:53 PM
04/29/19 10:53 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I don't really care about having the correct finish, I'd just like the correct color. It is a race car not a show car. I'd think I'd could find B5 in a spray can somewhere. I've looked at most of the usual suspects so far and I don't see anyone selling the classic colors in a can. I've had local parts store/paint places put that in a can for me. And I live in rural Arkansas so we have nothing. I was doing under the hood. I did base coat/clear coat and it turned out perfect but you can get the one pass paint.
2011 Drag Pak Challenger
[Re: Morty426]
#2652684
05/06/19 05:16 PM
05/06/19 05:16 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Brite Blue Poly. Ditzler 14096 and Dark Blue Poly Ditzler 14090
Bright Blue was on the roof rails.
Dark Blue on everything else.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
