Valve train noise #2652321
05/05/19 04:56 PM
05/05/19 04:56 PM
WV
WV Runner Offline OP
WV
I got a 493 stroker and running the comp car xr292hr-10 hydraulic roller cam. Preload is set at 1/2, it has a tic sound. Should I go to 3/4 or is something perhaps wrong with a lifter?
Re: Valve train noise [Re: WV Runner] #2652368
05/05/19 07:13 PM
05/05/19 07:13 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Is it a single click or are all 16 making noise like a watch sound? Double check that one or more lifter wasn't on the lobe when the preload was set. There have been some other threads here that got into this noise bit with hyd. roller cams. I don't know how but some of them evidently make noise. Like you, I would be bothered if there was excessive noise with a hyd. setup.
Re: Valve train noise [Re: WV Runner] #2652510
05/06/19 09:54 AM
05/06/19 09:54 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Start by googling “hydraulic roller lifter noise”
Re: Valve train noise [Re: fast68plymouth] #2652521
05/06/19 10:21 AM
05/06/19 10:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Everyone of the hyd roller lifters makes more noise than people
expect.. most think it should be like a regular hyd lifter but no way..
I put a set in my buddies 408ci and they were noisier than the regular
hyd lifters.. he wasnt real happy with them but they are still in there
wave
Re: Valve train noise [Re: MR_P_BODY] #2652765
05/06/19 09:42 PM
05/06/19 09:42 PM
WV
WV
I tried them at 3/4 and they was very noisy, back to 1/2 and much better. Good to know it’s normal for a little noise, makes me feel better I can live with a little noise. Probably won’t hear it with the hood on
Re: Valve train noise [Re: WV Runner] #2652828
05/07/19 03:04 AM
05/07/19 03:04 AM
If you have 3/8x24 rocker adjuster screws try setting the preload hot at 1/4 to 1/3 of a turn from zero preload and let us know if that helps or not.
If you are running 7/16x20 size adjusters try between 1/10 and 1/4 turn preload hot scope twocents
Re: Valve train noise [Re: Cab_Burge] #2652841
05/07/19 07:14 AM
05/07/19 07:14 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
fast ramps = more noise. if all 16 are "talking" to you then i'd say "nature of the beast".
Re: Valve train noise [Re: lewtot184] #2652899
05/07/19 10:03 AM
05/07/19 10:03 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Is the hydraulic roller lifter noise issue people have mentioned on a fairly regular basis a lifter brand-specific thing?
