Tire size questions, For a 73 B body w/ 15" rallyes #2652274
05/05/19 02:14 PM
05/05/19 02:14 PM
SINY
SanityLost Offline OP
SINY
My Car originally came with 14" rallye rims. I'm currently looking into going up to the 15x7 rallye. Looking at the ones that either Wheel vintique and Coker tire offer (probably same manufacturer???)
The tires I'm looking at are BF Goodrich radial T/A and the sizes are as follows, the rear 275/60/15 and on the front 245/60/15. Now should I go with the 60 series in the front? will the 60 Series clear? OR should I go with a 70 Series tire.
If anyone has a 73/74 Road runner OR satellite with this set up or close to it please post up some pictures and findings,
Thanks,Jeff
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: SanityLost] #2652280
05/05/19 02:41 PM
05/05/19 02:41 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I have the WV rallyes on my 73 RR. 15x8, 4.5 backspace with 275/60s on the rear. Fits well. 15x6 on the front with 205/70s on the front. Can't remember the offset. Going with 215/70s for the front next time. The 73 RR has a large front fender opening and I think a taller tire will look better.
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: SanityLost] #2652313
05/05/19 04:17 PM
05/05/19 04:17 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Originally Posted by SanityLost
…... I'm currently looking into going up to the 15x7 rallye. …..
sounds perfect - Chrysler Corp. never put 70-series tires on a 15x7.0" wheel an any B or E-body - from the factory a '73 B-body with 15x7.0"s would've had G60-15s all around (245/60/15)
here's a '72 scope
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: 6bblgt] #2652326
05/05/19 05:12 PM
05/05/19 05:12 PM
SINY
SINY
Thank you for the info, LOVE the look of the Poly's but cant get past the "drive" of them....Also LOVE the 72 pictured
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: SanityLost] #2652327
05/05/19 05:15 PM
05/05/19 05:15 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
A word of warning on larger size Radial TA’s so called raised white letters.
Ever since Michelin and Coker took over manufacturing and marketing of these iconic tires,,,, the larger sizes are no long raised white letters,,,,they are raised brown letters. The smaller sizes back then were not affected. I do know exactly the cause.
Michelin replaced those on my 71 Vette under cosmetic warranty 2 times. Before allowing them to do again when the third set turned brown,,,,less than 30 days, I reversed them and but the brown walls in.
There are several threads on this forum that covers this subject,,,with photos, in detail. This was a couple years ago,,,perhaps they have reformed their manufacturing processes.
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: SanityLost] #2652581
05/06/19 12:06 PM
05/06/19 12:06 PM
central il.
second 70 Offline
second 70  Offline
central il.
Jeff not a road runner but these are 225/70/15 on 7" rims front and 275/60/15 on 8" rear.
Too bad you don't live closer I have a set of almost new rallye rims and tires bfg ta 225/70/15 and 275/60/15 nitto's you could try and see how they look and would probably sell them since I don't need 3 sets of wheels.
Mike
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: SanityLost] #2653699
05/09/19 01:18 PM
05/09/19 01:18 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Don't like the way the bias-plies drive? Here's an alternative...........
BFG T/A's white letter in with "GOOD YEAR POLYGLAS" stenciled on them.
Screen Shot 2017-11-09 at 4.35.41 PM.pngScreen Shot 2017-11-08 at 3.44.01 PM.png
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: 71 Charger R/T] #2653949
05/10/19 09:37 AM
05/10/19 09:37 AM
moparx Offline
moparx  Offline
good way to keep the BFG letters from turning brown. biggrin however, how do you keep 'em black ?
beer
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: moparx] #2653985
05/10/19 10:57 AM
05/10/19 10:57 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
beer
I would think you use the backside of the tire no?
Ron
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: RJS] #2654271
05/11/19 10:00 AM
05/11/19 10:00 AM
moparx Offline
moparx  Offline
beer
Ron
DUH, my old mind tricked me again ! i shoulda known better ! panic my old man used to always say : "get a sack fulla quarters and back up to the azz kickin' machine !" i need to take his advice......
beer
Re: Tire size questions, For a 73 B body w/ 15" rallyes [Re: moparx] #2654326
05/11/19 01:10 PM
05/11/19 01:10 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I have used 303 protectant for over 25 years on my tires. Have found nothing better to regain that low sheen satin like look. I also use on radiator hoses, interior vinyl, even some leathers, like in our 300 B, and many other places requiring detailing. There are now a number of decent non silicone based protectants,,,I have found nothing better, so why switch.
I should note on my earlier post,,,that almost all Michelin tires,,,even black ones will turn brown. So if you reverse your Radial TA’s the black walls too will eventually brown. These dopes began a number years ago added silicone(think Armour All and how it brown’s everything it touches) to their rubber compounds,,,,yes the have their reason, to zero benefit to their clients. Some other tire manufacturers do this too,,,,,I say avoid them if you can.
However a good dose of 303 every month or so will control this,,,unfortunately does nothing to turn Raised Brown Letters to white again.
