Over-assisted steering
#2651896
05/04/19 01:26 PM
05/04/19 01:26 PM
Posts: 401 Norway
General 68
Norway
70 Challenger, factory power steering box, Saginaw pump. Had the box out to put in new seals in the shaft end. To get there the steering valve was pulled. All went back together smoothly with a few taps on the valve so the car not self steers. Problem is that the steering now is way over-assisted - dangerously light with literally no effort needed to turn the wheels. Something happened during reassembly, but what? Any idea what causes over- assisting? Seems to me that nothing restricts the flow. I also put in new o-rings between valve and gear box.
Re: Over-assisted steering
[Re: General 68]
#2652198
05/05/19 11:47 AM
05/05/19 11:47 AM
RapidRobert
that this box was ok until I took off the steering valve to change seals om the shaft end. Go back in see what got fubared when changing the seals on the shaft end.
[Re: RapidRobert]
#2652219
05/05/19 12:32 PM
05/05/19 12:32 PM
Posts: 401 Norway
General 68
Norway
RR: I can not see what could go wrong by changing ONLY the outer seals. But I wonder if the steering valve that hadde to come off has something to do with this. It is a spring and a valve pin in there. 12" steering wheel, 235/70 tires and big Block and the wheel will turn with only a touch from a finger. What exactly does the steering valve do other than letting pressurized oil in? Does it meter the amount og flow too when the input shaft is turned? If so I suspect the valve is not moving as it should.
[Re: General 68]
#2652289
05/05/19 03:02 PM
05/05/19 03:02 PM
RapidRobert
General I do not have an ans to your Q cuz I ain't into PS but I am strickly thinking of (KISS) Keep It Simple Sam, that something was moved/bumped/altered out of whack when those seals were changed.
[Re: General 68]
#2652334
05/05/19 05:46 PM
05/05/19 05:46 PM
RapidRobert
unless someone comes up with something specific I'd probably go back into it & checkout/go thru everything (assuming the over assist is a pain & it sounds like it is) & there could be a possibility that it will worsen or leak etc.
