5/8" spring eye bolt vs 1/2"
#2651871
05/04/19 12:21 PM
05/04/19 12:21 PM
Posts: 220 Aurora, CO
jbeintherockies
Aurora, CO
Hello, I have adjustable front spring mounts that use the 5/8" spring eye bolt. The springs are Mopar Performance 1-1/2" spring eye size. I just bought the P-S-T polygraphite spring eye bushings for the 1-1/2" spring eye. However, the bushing shell where the spring eye bolt passes through the spring eye bushing is 1/2", not 5/8". I will call P-S-T on Monday to see if they have bushings that can accommodate the 5/8" spring eye bolt diameter. If they don't, now what do I do? I guess my only option is to bring the springs to a locale spring shop and have them install custom bushings (probably rubber junk) that accommodate the 5/8" spring eye bolt. Any other options? I really doubt I'm the first to come across this dilemma
Re: 5/8" spring eye bolt vs 1/2"
[Re: jbeintherockies]
#2651893
05/04/19 01:13 PM
05/04/19 01:13 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
If you are comfortable with the 1/2 inch bolt, anyone with a lathe and any skill can easily make some adapter washers. I would be happy to make them for you if you need me to. Just PM me.
[Re: markz528]
#2651906
05/04/19 02:29 PM
05/04/19 02:29 PM
jbeintherockies
Aurora, CO
If you are comfortable with the 1/2 inch bolt, anyone with a lathe and any skill can easily make some adapter washers. I would be happy to make them for you if you need me to. Just PM me. I am having trouble visualizing adapter washers. Can you please provide a picture to help me? The issue is with the size of the sleeve that goes through the polygraphite spring eye bushings. The sleeve that comes with the kit (at least for a '68 Barracuda) accommodates a 1/2" bolt. I guess A-bodies came with 1/2" spring eye bolts. I am thinking about getting sleeves that accommodate the 5/8" diameter bolt that my car now has and then drilling out the polygraphite spring eye bushings to accommodate the 5/8" sleeve. I'm not going to do anything until I talk to PST on Monday. Just trying to figure out what my options are.
[Re: Locomotion]
#2651908
05/04/19 02:31 PM
05/04/19 02:31 PM
jbeintherockies
Aurora, CO
Are the walls of the 1/2" PST sleeves thick enough to allow being drilled out to 5/8"? (That will leave the walls only 1 /16" thinner than they are now.) Might need a machine shop, especially if the sleeves are hardened.
FWIW, I also like to put the bolts in with anti-seize in the sleeve. I wasn't going to drill out the sleeve; too thin as you suggested. Good idea on the bolts going through the sleeve. My Jeep had the driver's side bolt rust (weld) to the sleeve and the spring had to be cut apart to get the bolt out.
#2651944
05/04/19 04:35 PM
05/04/19 04:35 PM
markz528
Morrow, OH
If you are comfortable with the 1/2 inch bolt, anyone with a lathe and any skill can easily make some adapter washers. I would be happy to make them for you if you need me to. Just PM me. I am having trouble visualizing adapter washers. Can you please provide a picture to help me? The issue is with the size of the sleeve that goes through the polygraphite spring eye bushings. The sleeve that comes with the kit (at least for a '68 Barracuda) accommodates a 1/2" bolt. I guess A-bodies came with 1/2" spring eye bolts. I am thinking about getting sleeves that accommodate the 5/8" diameter bolt that my car now has and then drilling out the polygraphite spring eye bushings to accommodate the 5/8" sleeve. I'm not going to do anything until I talk to PST on Monday. Just trying to figure out what my options are. This would be an example. The washer fits in the 5/8" hole and properly locates the 1/2" bolt.
[Re: markz528]
#2652027
05/04/19 10:07 PM
05/04/19 10:07 PM
jbeintherockies
Aurora, CO
Mark, yes, that would probably fix the issue. I don't have much clearance between the spring eye bolt head and the frame rail. So the "boss" of the washer might push the head of the bolt too far out and then it would interfere with the frame rail. I would be willing to try it anyway. Let me call PST on Monday and see what they can do for me. Thank you for drawing up the diagram, I appreciate it
#2652028
05/04/19 10:09 PM
05/04/19 10:09 PM
Posts: 22,696 Bitopia
jcc
Bitopia
FWIW, I also like to put the bolts in with anti-seize in the sleeve. I wasn't going to drill out the sleeve; too thin as you suggested. Good idea on the bolts going through the sleeve. My Jeep had the driver's side bolt rust (weld) to the sleeve and the spring had to be cut apart to get the bolt out. I'm not convinced they are too thin. They only press against a relatively soft material by whatever force the the thru bolts applies. If the thru bolt has sloppy fit, they may hammer the the sleeve, if tight, not sure it would matter. Factory design was for maybe 100K? trouble free miles, your likely use is? Difficulty in enlarging to 1/16" wall would be be biggest hurdle IMO. edit, upon further reflection, if the 5/8" thru bolt is max tightened, I suspect distorting the 1/16" thick bushing is likely, and would quickly promote its failure, so maybe I am now convinced?
[Re: jcc]
#2652170
05/05/19 11:11 AM
05/05/19 11:11 AM
Posts: 19,488 north of coder
moparx
is there enough room on your bracket to drill a 1/2" hole above, or below, the original 5/8" hole without having the spring itself rub the floor pan ? if you need [or want to] to relocate/center the rear tires in the 1/4 openings, this may be the time to drill the holes you need to do so in the brackets. you could possibly gain up to 1/2" or so. you may, however, need to get a longer driveshaft doing this. just a couple of suggestions that may work for Your Application. the quality back in the day was all over the place.
#2652486
05/06/19 08:51 AM
05/06/19 08:51 AM
jbeintherockies
Aurora, CO
What size spring eye bolt comes on a b body? Is it 1/2" or 5/8"? How much different is the width of an a-body leaf spring vs b-body leaf spring? I'm wondering if b-body sting eye bushings would work with an a-body that has the 5/8" spring eye bolt Edit: I called Mancini and they advised I use the front spring eye bushings for an E-body. The E-bodies use the 5/8" spring eye bolt. I believe all Mopar passenger car leaf springs are the same width (2.5"). However, even the E-bodies used different spring eye diameters: 2" on small blocks and 1.5" on big blocks. So, I'll try spring eye bushings for a big block 1970 Barracuda and see how that goes.
