Trunk Divider Cardboard and Insulation #2651846
05/04/19 11:24 AM
05/04/19 11:24 AM
Spanaway, Washington State
P
patosmith Offline OP
P
I have a 72 Challenger that is missing the trunk divider cardboard.
I bought the cardboard and the insulation but I am not sure of the proper installation since the car didn't have it when I bought it.
Does anyone have a pic or can you describe the proper installation?
How is it fastened in place and I assume the insulation goes on the cabin side of the cardboard.
Thanks in advance.
Re: Trunk Divider Cardboard and Insulation [Re: patosmith] #2651863
05/04/19 12:08 PM
05/04/19 12:08 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I have yet to see one with an insulation ..the panel just lays flat and hooks onto the 2 top seat hooks
Re: Trunk Divider Cardboard and Insulation [Re: AARCONV] #2651864
05/04/19 12:12 PM
05/04/19 12:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yep, no insulation on the originals.
Re: Trunk Divider Cardboard and Insulation [Re: patosmith] #2651990
05/04/19 07:30 PM
05/04/19 07:30 PM
3
340clone Offline
340clone  Offline
I am not sure if Challengers had insulation form the factory or not, but it couldn't hurt to add it. If it helps, I have a '74 Charger SE that had the jute-insulated side facing out to the trunk, from the factory. The insulation was visible when you opened the trunk. When I restored the car, I replaced the old board and faced the insulation side towards the rear seat back. That way, the trunk looked cleaner and the jute padding was less likely to get damaged or collect dirt. Not sure which way would be correct, but I would face the cardboard side towards the trunk.
Re: Trunk Divider Cardboard and Insulation [Re: patosmith] #2651996
05/04/19 07:47 PM
05/04/19 07:47 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The divider just hangs on the back seat hooks with the insulation pointing toward the back seat.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
