Guys, teach me about 340 blocks #2651292
05/02/19 04:55 PM
05/02/19 04:55 PM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Hello everybody. I'm buying a 340 block in Brazil but to be honest I don't know to much about this blocks. What kind of details I need to pay attention?
I'm planning to build a Pump Gas N/A engine, 12.0CR, solid flat tapped cam, Victor Heads, Tunnel Ram, Steel main caps... Can I drill to use 4 bolt main caps or this block like 318 no has enough material to add more 2 splayed bolts?
How is safe to bore for a N/A Street engine?
Here is a picture of the cast number.
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Guys, teach me about 340 blocks [Re: 360tripleblack77] #2651320
05/02/19 06:40 PM
05/02/19 06:40 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I am told that drilling for four bolt mains will actually weaken the block.
I have a set of Milodon caps and am considering just line boring and using the two bolt configuration on my next deal.
Casting number says 71-73 340 block.
I would have the block sonic tested before I decided how large to bore it.......especially if you want to really open it up.
I wouldn't sweat .030 over , but if you want to open it up , better to know how much meat you have there.
Stroking is the best way to add inches to my way of thinking.
Re: Guys, teach me about 340 blocks [Re: 360tripleblack77] #2651325
05/02/19 07:00 PM
05/02/19 07:00 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
12.0 CR is pump gas? Lots of alcohol in the gas down there? Me personally, I'd be building a 360 - probably not as rare or $$, cheaper, bigger bore, lot's of stroker kits available, won't have to build it as radical as the 340. But..most should go .060 but get it sonic checked. 12.0 will need head studs and really good gaskets - 4 bolts per cylinder can lead to sealing issues. Years ago guys o-ringed those blocks, nowadays Cometic might make a head gasket to handle it. May need oiling mods too, if you are looking to turn some RPM. The MP/DC Engine manuals are your friend.
Re: Guys, teach me about 340 blocks [Re: Sixpak] #2651326
05/02/19 07:21 PM
05/02/19 07:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a 340 block that has 4 bolt mains but understand that the outer
main bolt are 3/8" and they go straight down.. been a great block for
years now.. I bought it from a dirt roundy round racer.. all my blocks
are 340 based.. even my 2 bolt blocks I turn to 8000+ rpms.. sonic
check ALL blocks
wave
Re: Guys, teach me about 340 blocks [Re: 360tripleblack77] #2651328
05/02/19 07:25 PM
05/02/19 07:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
Is your pump fuel straight Ethanol or Methanol now?
As far as main caps I wouldn't, and don't', use steel caps on any cast iron block, ductile iron or maybe aluminum but not steel tsk twocents work
As far as bore size I would bore it just big enough to get the bores straight now and leave some meat for later development up
I have built several 340 NHRA legal stocker 340 motors that made 430 HP at 5900 RPM with stock 1971 heads, intake, carb and NHRA legal hydraulic camshafts and lifters shruggy That was a long time ago, early 1990s, much better parts available now scope
I built one pump gas 340 4.0 inch long stroker motor with a set of race mildly ported race W2 heads that made 514 HP with one 850 CFM carb. on a cast single plane W2 intake using CA 91 octane pump swill work
Stroke that rascal and put some good heads on it and let it rock thumbs
Re: Guys, teach me about 340 blocks [Re: 360tripleblack77] #2651347
05/02/19 07:58 PM
05/02/19 07:58 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Looks like you are going to make some power. I would pass on a stock block and pay the money for a R3 or a Ritter now, but thats me.
"Just a Bracket car dressed up like a streetcar"
Re: Guys, teach me about 340 blocks [Re: Just-a-dart] #2651381
05/02/19 09:51 PM
05/02/19 09:51 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Great advice.
If you want to make serious steam , you will never regret good parts in the basement.
Re: Guys, teach me about 340 blocks [Re: tubtar] #2651444
05/03/19 04:17 AM
05/03/19 04:17 AM
Germany
stickman60 Offline
stickman60  Offline
Germany
He will have a really hard time finding a R3 block (=extinct) and having it shipped to Brazil.
And the Ritter block will cost him 6 - 7K before he can bolt his parts on.... the 340 block he already has.
Re: Guys, teach me about 340 blocks [Re: stickman60] #2651488
05/03/19 09:37 AM
05/03/19 09:37 AM
Thanks for all advice Guys. R3 or Ritter is not an option for me unfortunately. Price + shipping + taxes to ship to Brazil is unbelievable expensive. Best pump gas in Brazil has 96 oct and 30% of ethanol. Currently I`m running with 12.0CR on this Pump Gas, Cometic head gasket and ARP bolts. No Issues so far. This engine has a 318 block, 3.58 Scat Series 9000 and overbored to 4.000". After all machine works I did a sonic check at the cylinders bore and the thin wall measure that I found was 0.148".
I'm looking forward to use Victor Heads but this heads has 2.15 intake valves and I believe that 4.000" bore is not enough for a good valve shroud. This is the main reason that I'm thinking change for a 340 block, maybe use 4.080" or 4.100"
Best 1/8 mile ET
Re: Guys, teach me about 340 blocks [Re: 360tripleblack77] #2651544
05/03/19 12:06 PM
05/03/19 12:06 PM
fullmetaljacket Offline
If I'm correct, isn't that block by virtue of the casting numbers, a 6ix pack 340?
I'd also agree that a 360 is the cheaper more viable way to go and make gobs of torque without the strain.
Re: Guys, teach me about 340 blocks [Re: fullmetaljacket] #2651549
05/03/19 12:17 PM
05/03/19 12:17 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I would stick with the mains as is. I don't like to drill into stock webs. not much there to begin with. the only reason to change caps would be to keep the cap material from splitting. I have never seen a mopar cap split....just web cracks.
Re: Guys, teach me about 340 blocks [Re: fullmetaljacket] #2651562
05/03/19 12:57 PM
05/03/19 12:57 PM
Washington
madscientist Offline
Washington
That's not a T/A block.
Re: Guys, teach me about 340 blocks [Re: fullmetaljacket] #2651565
05/03/19 01:15 PM
05/03/19 01:15 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nope.
T/A blocks have their own casting number & the letters TA actually cast in as well.
Re: Guys, teach me about 340 blocks [Re: Alaskan_TA] #2651581
05/03/19 01:49 PM
05/03/19 01:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One of my blocks is a TA block.. its the for runner to the X block..
thicker main webbing
EDIT
that 6 at the end of the number is just the casting box number.. that
just another check to see if that casting box is having any issues
wave
Re: Guys, teach me about 340 blocks [Re: MR_P_BODY] #2651633
05/03/19 04:33 PM
05/03/19 04:33 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Save the big bores for the X, R, & Ritter blocks. OE 340 blocks are thin. .030 is considered safe. Any bigger should be checked. Personally, I wouldn't go any larger than needed, unless there was a real reason. They aren't making anymore and I don't want to use it up with one overbore.
2 bolt mains and stock caps aren't the weak point. 550 to 600 is about the safe limit. Early 360s can go to 340 size bores.
Re: Guys, teach me about 340 blocks [Re: CMcAllister] #2651671
05/03/19 06:33 PM
05/03/19 06:33 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
I agree with everybody, I ran 340s for years hard to find a good block that sonics well, switched to a 360 ( Magnum ) block awhile back I like it better more torque and top end. Now running an R3 block with a 4 inch stroke, Indy 360-1 heads
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Guys, teach me about 340 blocks [Re: 360tripleblack77] #2651677
05/03/19 06:40 PM
05/03/19 06:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. In my opinion there's no need to butcher the block the head will make plenty of power
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Guys, teach me about 340 blocks [Re: WHITEDART] #2653439
05/08/19 04:07 PM
05/08/19 04:07 PM
Thank you guys! Block is over 0.30 and was sonic tested and magnafluxed. No issues and are ready to build a 4.070".
Now I need to decide what stroke I should use. 3.790 x 4.000 or 4.125?
Best 1/8 mile ET
Re: Guys, teach me about 340 blocks [Re: 360tripleblack77] #2653444
05/08/19 04:23 PM
05/08/19 04:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a couple of 3.79 and a 4.00 strokes.. I think you would be happier
with a 4.00 stroke.. plenty of them around and if you wanted a cast crank
they are pretty cheap.. all my stuff is billet or forged.. the 3.79 are billet
ones
wave
Re: Guys, teach me about 340 blocks [Re: MR_P_BODY] #2653469
05/08/19 05:47 PM
05/08/19 05:47 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
If I were doing it, stroke would be determined by whether or not I was going to use stock or custom length rods and custom pistons. I would want to take advantage of the LA deck height to keep the rod ratio at least close to stock.
