what lug studs, where to order 5? #2651257
05/02/19 03:08 PM
05/02/19 03:08 PM
Andrewh Offline OP
Andrewh  Offline OP
I have the rear axle out on my 65 coronet.
the driver side is still left handed.
I figure since it is out, I should swap to right handed ones.
I can't seem to find what size they should be or a good part number.
I keep getting metric stuff.
Rockauto even lists a set of 5 that say right handed, but when you go to info it says left handed threads.
Also is there a go to now for acorn lug nuts that aren't going to separate? I remember there was a problem with the outside shells coming off.
Re: what lug studs, where to order 5? [Re: Andrewh] #2651259
05/02/19 03:18 PM
05/02/19 03:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
When I added discs to my 8 3/4 I used 10 of DORMAN 610446. A bit longer than stock with a dog point, works fine. Used Rock Auto for them. As for nuts, I just used the OEM open style for an 87 Diplomat, DORMAN 711831
Don't be the exception.
Re: what lug studs, where to order 5? [Re: Supercuda] #2651289
05/02/19 04:45 PM
05/02/19 04:45 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks, found a few places I can get those.
Re: what lug studs, where to order 5? [Re: Andrewh] #2651548
05/03/19 12:15 PM
05/03/19 12:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The longer studs might be a problem with acorn nuts. Doc Diff has the original style:
https://www.doctordiff.com/8-3-4-wheel-lug-studs.html
