Another “what cam” thread... #2650055
04/28/19 11:55 PM
04/28/19 11:55 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Hello all, I’m in the process of rebuilding a 426 max wedge clone motor for my uncle. Looking for a cam recommendation. It is a ‘65 426 block, stock .010 crank and rods, TRW 11:1 pistons, 452 heads with a valve job and light port cleanup. Crane gold rockers. Obviously it has a A&A repo crossram and max wedge exhaust manifolds. Being a small block and aftermarket head guy, I’m used to larger lift cams... what would be a good cam for this 426? It’s a street cruiser, so he’s mainly after that ‘60s race sound and drivablity more than actual performance. It’s going in a ‘62 Dart with a 3000 converter and 3.55 or 3.91 gears. Thanks
Re: Another “what cam” thread... [Re: 340_Dart] #2650079
04/29/19 03:10 AM
04/29/19 03:10 AM
Is this a pump gas street motor? If so you will probably have detonation problems on todays pump swill with that much compression work twocents
As far as the cam I would look for a solid lifter flat tappet grind with as much lift you can get with between 245 to 260 degrees duration at .050 with the symmetrical lobes and maybe a little more duration(5 to 10 degrees) on the exhaust lobes and have it ground on 105 to 108 lobe separation angles and install it with between 3 to 6 degrees advance on the intake lobes scope
As far as that clone M.W. intake for stock type 440 heads I don't know anyone who has used them and like them shruggy
I'm a little bias on M.W. cars and motors due to owning and racing several of them, lucky me boogie
If I was advising your uncle I would tell him to run a six pack intake and carbs with 9.5 to 1 compression just to make some of the purist mad devil stirthepot grin
Re: Another “what cam” thread... [Re: Cab_Burge] #2650089
04/29/19 06:45 AM
04/29/19 06:45 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
If you are looking for the sound and performance from a retro cam, the .590 purple shaft was always my favorite. Will work well with your combo.
Re: Another “what cam” thread... [Re: Cab_Burge] #2650138
04/29/19 10:02 AM
04/29/19 10:02 AM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Yeah Cab, I'm thinking it may have problems on pump gas.... But that's the cards I've been dealt with this build. Backstory of this motor, the longblock was apparently built in the 80s (guessing from the bearing date codes) and never used, My uncle bought it 10-12 years ago and got it running in his Dart with a single 4bbl and it sat... Last year at Carlisle he bought the cross ram setup and manifolds. Went to put the cross ram on last fall and noticed a loose rocker, further investigation showed the cam had a flat lobe...So he asked me to go through it. I cleaned and checked it out, new cam bearings, crank polished, and new rod and mains are on order.
I know the pistons are TRW replacement 11:1 pistons. I'm hoping once I get checking piston height and head CCs that i'll end up with less than 11:1 compression. It previously had a Crane ZIP 510 solid FT cam in it.
.ZIP-510 for the B/RB
.340" intake lobe lift, .3455" exhaust lobe lift,
Valve lash is .028" intake, .032" exhaust at operating temperature.
The duration at .050" tappet lift is 254 degrees intake, 264 degrees exhaust.
Lobe separation is 112 degrees.
Re: Another “what cam” thread... [Re: 340_Dart] #2650155
04/29/19 10:36 AM
04/29/19 10:36 AM
NJ
cb1289 Offline
cb1289  Offline
NJ
Crane Zip 510. There's your cam right there! A great cam for that combo.
Sorry, I reread and saw the flat cam lobe after I replied.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Another “what cam” thread... [Re: 340_Dart] #2650177
04/29/19 11:37 AM
04/29/19 11:37 AM
Washington
madscientist Offline
Washington
I'd call Jim at Racer Brown and spend some time on the phone with him. I run 11:1 on pump gas with iron heads and I'm not having issues. He has some lobes just for stuff like this. It's worth your time to spend some time on the phone with him so you aren't guessing and doing it twice.
Re: Another “what cam” thread... [Re: 340_Dart] #2650183
04/29/19 12:08 PM
04/29/19 12:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
MP .528, or something along those lines, based on the description above.
I also agree that 11.0 CR with open chamber iron heads will be a problem on pump gas, if the CR is really that high.
Re: Another “what cam” thread... [Re: Cab_Burge] #2650326
04/29/19 07:39 PM
04/29/19 07:39 PM
gregsdart Online content
gregsdart  Online Content
Andyf liked a certain flat tappet mopar cam, he should chime in and spill the beans. Seems any car with stock manifolds could only use so much duration and overlap. You could send him a pm for his input.
Re: Another “what cam” thread... [Re: gregsdart] #2650393
04/29/19 10:43 PM
04/29/19 10:43 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I am nearly certain AndyF tested the MP 528 suggested above and for whatever reason it made more power than anything with exhaust manifolds.
Re: Another “what cam” thread... [Re: 340_Dart] #2650409
04/29/19 11:55 PM
04/29/19 11:55 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
What about a factory 64 Max Wedge stage III cam??
Re: Another “what cam” thread... [Re: Belvedere1] #2650524
04/30/19 12:44 PM
04/30/19 12:44 PM
Which one, 415 or 425 HP? The 1963 cam is the same for both motors, not sure about the specs. on the 1962 413 M.W. work
All of them where drag race cams, not mild at all at that time work
There are a lot better choices on cams today for most any type build up
Re: Another “what cam” thread... [Re: Cab_Burge] #2650687
04/30/19 09:57 PM
04/30/19 09:57 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I think the stage III was for 64 425 hp and was the hottest cam of the max wedge years. Not sure of the specs but around .520 and 250 something?
Re: Another “what cam” thread... [Re: Belvedere1] #2650725
04/30/19 11:31 PM
04/30/19 11:31 PM
Originally Posted by Belvedere1
I think the stage III was for 64 425 HP and was the hottest cam of the max wedge years. Not sure of the specs but around .520 and 250 something?
The 413 and most of the 1963 M.W. motors where stage 1 motors, mid year in 1963 Mopar came out with the Stage 2 425 HP motor that had the same carbs and camshaft as the 425 HP 1964 M.W. came with.
All the 1964 M.W. motors where considered and called Stage 3 is what I remember from back then scope
I think all the 1963 cams where considered 300 degree total duration with right at .509 lift, the 1964 415 HP motors had a little more duration, either 312 or 316 degrees advertised with around .510 lift at the valves and the 1964 425 HP motors had the biggest wedge made for production cars with 320 degrees advertised duration and right at .520 valve lift work
All the Mopar ductile iron rocker arms I've check where no where near perfect, most didn't meet the 1.5 ratio, always less whiney
Re: Another “what cam” thread... [Re: BradH] #2650737
05/01/19 12:18 AM
05/01/19 12:18 AM
AndyF Offline
AndyF  Offline
Yep, that is what I'd put in there. The MP .528 will pull hard and the car will seem really fast even if it isn't. It will be fun to drive on the street and sound good. If you put a real race cam in there then it might sound mean but it won't be any fun to drive.
Re: Another “what cam” thread... [Re: AndyF] #2650796
05/01/19 10:00 AM
05/01/19 10:00 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If I had a 528 cam sitting on the shelf, I’d probably use it in something like that.
But at the nearly $400 they go for now........ there’s a lot of options.
Re: Another “what cam” thread... [Re: fast68plymouth] #2651035
05/01/19 08:22 PM
05/01/19 08:22 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Dwayne, theoretically, couldn't you just essentially order a "custom" grind through your cam supplier with the 528 specs for cheaper than what the MP cam cost?
Re: Another “what cam” thread... [Re: fast68plymouth] #2651046
05/01/19 08:56 PM
05/01/19 08:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
But at the nearly $400 they go for now........ there’s a lot of options that are better
Fixed
Re: Another “what cam” thread... [Re: BSB67] #2651066
05/01/19 09:56 PM
05/01/19 09:56 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Fixed
Not much, according to a lot of testing.
http://www.moparts.org/Tech/Archive/bb/550hp.html
http://www.moparts.org/Tech/Archive/bb/Lobe.html
Re: Another “what cam” thread... [Re: Skeptic] #2651117
05/02/19 06:52 AM
05/02/19 06:52 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Fixed
Yes, I read those 15 year old articles 15 years ago. Nice articles, and a thanks to Andy F. for them as well as others.
Re: Another “what cam” thread... [Re: BSB67] #2651155
05/02/19 10:00 AM
05/02/19 10:00 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The engines we are talking about were engineered 60 years ago, any improvements will be incremental, not revolutionary. In the context of the OP, i.e. street cruiser, exhaust manifolds, high street CR - not dedicated race engine. Throwing a lot of dyno time and more expensive components-i.e. roller cams, beehive springs, ect- there could be improvements here and there, but in the end it's a 1950s era engine. twocents
