Re: Mopar electronic distributor pig tail
[Re: mopars4ever]
#2650485
04/30/19 10:55 AM
04/30/19 10:55 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
Thanks, but I was hoping to find a new one locally....I thought Standard Ignition made one but my local parts store can't find it and I've googled with no luck...
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#2650502
04/30/19 11:49 AM
04/30/19 11:49 AM
RapidRobert
On a side note people have suggested to spiral those wires together along their length
[Re: Big Squeeze]
#2650512
04/30/19 12:20 PM
04/30/19 12:20 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
The new replacement pickups come with them I have bought them at junkyards off of old cars also
[Re: fal3]
#2650529
04/30/19 01:12 PM
04/30/19 01:12 PM
Big Squeeze
Oologah, Oklahoma
I bought one years ago when I converted to electronic distributor. Bought it from Dorman @ auto parts store. I know have too...It must be discontinued because I can't find it....
[Re: buildanother]
#2650574
04/30/19 03:21 PM
04/30/19 03:21 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
Is it the same as a battery tender connector? Just a thought.... maybe a bad thought lol
Scott
1969 Super Bee, 383/4 speed
[Re: tman]
#2650659
04/30/19 08:20 PM
04/30/19 08:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What makes you think he needs it for the pickup side?
[Re: Andrewh]
#2650685
04/30/19 09:55 PM
04/30/19 09:55 PM
RapidRobert
Unless you wanted OE I would go with the O'reillys item & any 2 wire trailer pickup of that type would work fine & if needed you can alter rotor phasing by reversing the phasing on the 2 leads when you solder em together.
[Re: Andrewh]
#2650777
05/01/19 08:41 AM
05/01/19 08:41 AM
Big Squeeze
Oologah, Oklahoma
Is the one you bought the same size as the distributor connector? The ones I've found at the parts store look the same but they're smaller.
[Re: Big Squeeze]
#2650823
05/01/19 11:42 AM
05/01/19 11:42 AM
RapidRobert
I'd go ahead & grab it & you cant go wrong for $4 & if it wont plug in to the other half then you are out only haveing to solder 4 wires instead of 2.
[Re: Big Squeeze]
#2650845
05/01/19 12:27 PM
05/01/19 12:27 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
Is the one you bought the same size as the distributor connector? The ones I've found at the parts store look the same but they're smaller. I noticed that as well. The NSS wire harness uses the same 2 pin and a single pin to make the connections, the trailer plugs are 90% the same but slightly off. It will 'work' and make an electrical connection but not have the oem fit up.
[Re: Supercuda]
#2650949
05/01/19 04:07 PM
05/01/19 04:07 PM
Posts: 566 WA
tman
WA
What makes you think he needs it for the pickup side? Based on the title of this thread. But I see now its the other side.
[Re: mopars4ever]
#2650969
05/01/19 05:03 PM
05/01/19 05:03 PM
Supercuda
About to go away
About to go away
up yours
Pretty sure they interchange. Except it's a lot cheaper to just buy the pig tail to fix the non pickup side than it is to buy a new pickup, cut off the pigtail and splice it in.
