D60 set up
#2650314
04/29/19 07:03 PM
04/29/19 07:03 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
When setting up a D60, are you guys using a set up bearing for your carrier, are you pulling the stock carrier bearings on and off or are you making your own set up bearings by honing standard bearings?
I’m getting ready to set mine up and would like to make it as uncomplicated as possible. I’ve done several forklifts but never a 60.
Re: D60 set up
[Re: VcodeR/T]
#2650320
04/29/19 07:17 PM
04/29/19 07:17 PM
NTOLERANCE
Madison Wi
Whether you buy some set-up bearings or hone a pair of new ones yourself...you're going to want some! Thanks. I do have a big hyd press and a proper bearing separator. But I think set up bearings will save a lot of time.
Re: D60 set up
[Re: NTOLERANCE]
#2650324
04/29/19 07:37 PM
04/29/19 07:37 PM
Posts: 11,557 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Honing bearings so they have a light press fit, so you can get them off without bending them up would make sense. The tool made by Randy's will make life much easier too.
Re: D60 set up
[Re: NTOLERANCE]
#2650447
04/30/19 08:31 AM
04/30/19 08:31 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I use a pair of honed carrier bearings. Definitely makes the job easier.
Re: D60 set up
[Re: an8sec70cuda]
#2650521
04/30/19 12:39 PM
04/30/19 12:39 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
I honed a set of used carrier bearings inner races and a rear pinion bearing for the Dana 60 and the 742 8 3/4 also I think I used a brake hone or maybe a very small cylinder hone, those races are hard so it takes some time before they will start to slip on and off
Re: D60 set up
[Re: WedgeFED]
#2650612
04/30/19 05:01 PM
04/30/19 05:01 PM
Posts: 5,161 CT
GTX MATT
CT
Hone the exact bearing PN you plan to use
