Loose ball joint
#2649934
04/28/19 03:40 PM
04/28/19 03:40 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
72 Cuda. While replacing the upper control arm bushings with offset ones I discovered the ball joint is loose. It won't tighten, one is stripped. What are my options? Oversized joint, new arms, welding?
11B40
Re: Loose ball joint
[Re: savoy64]
#2649948
04/28/19 04:26 PM
04/28/19 04:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Doctor Diff has a pair of brand new UCA's loaded for under $100. Not even worth messing with the old stuff at that price. https://www.doctordiff.com/upper-control-arms.html
[Re: Supercuda]
#2649959
04/28/19 05:14 PM
04/28/19 05:14 PM
JonC
Millinocket, Maine
Dr. Diff looks like the way to go, do the Moog offset bushings fit in these? And is that for a pair?
11B40
