Re: I finally did it. Installed my Hydroboost. Issue now.
[Re: Greentween]
#2649848
04/28/19 11:36 AM
04/28/19 11:36 AM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
The loops are still intact on both front and rear the flared fittings only moved forward about 1.25" each
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#2649870
04/28/19 12:38 PM
04/28/19 12:38 PM
Posts: 15,429 Omaha Ne
TJP
Omaha Ne
The light coming on indicates an imbalance in pressures between the front and rear side of the differential valve. Could be due to air in either side of the system or master, improper routing of the lines, a stepped bore master that delivers different pressures, or brakes that are applying at different times (check adjustment on rears for excess clearance).
[Re: TJP]
#2649992
04/28/19 08:15 PM
04/28/19 08:15 PM
Pyper70
Athens, Greece
I might have to wait for the adjustable bias valve to get proper pressures. I can't see it being air in the system but I can bleed them again...no problem.
This is the Master I installed
[Re: Pyper70]
#2650042
04/28/19 10:43 PM
04/28/19 10:43 PM
Posts: 552 LA & L.A.
MoparPosterChild
LA & L.A.
The brake light on the dash in my Duster comes on from time to time and I have hydroboost but I realized that the emergency brake lever that engages the emergency brake is a bit loose and slides around enough to engage the light sometimes.
2018 Dodge DEMON #18 1970 Plymouth Duster 406" Stroker 1969 Charger 500" Stroker 1964 Dodge Polara 426 GEN III HEMI 1970 Plymouth Cuda Hellcrate Project car 1974 Dodge Ramcharger Project car 2017 Chrysler Pacifica Limited 2017 Ram 3500 2012 Dodge Caravan R/T 1972 Charger Mopar 392 HEMI Stolen 2008 Challenger SRT-8 Gone 2010 Challenger SRT-8 Gone 2006 Charger SRT-8 Gone 2007 Charger R/T Gone
[Re: MoparPosterChild]
#2650081
04/29/19 04:06 AM
04/29/19 04:06 AM
Guitar Jones
An adjustable proportioning valve can be installed either in place of the factory valve or after the factory valve, not before it. So unless you use it in place of the valve the light will still be coming on. I would suggest driving it some if the brakes are working and then bleed them again.
#2650090
04/29/19 06:50 AM
04/29/19 06:50 AM
Pyper70
Athens, Greece
The brake light on the dash in my Duster comes on from time to time and I have hydroboost but I realized that the emergency brake lever that engages the emergency brake is a bit loose and slides around enough to engage the light sometimes. I remember that on my 70 Dart...it would flicker on and off....this is a solid ON until I release the brake pedal Talked to a friend who installed a few, he says the adjustable valve is needed but my bleeding sequence might need altering. I did it the old fashion way with drum brakes because I have them. RR, LR, RF, LF. He suggests to treat it like a disc/disc install and do it LF, RF, LR, RR. Hydratech instructions say to allow for 500 miles after initial testing to work out the kinks such as air pockets in the nitrogen reserve. Going to give them a call later today and see if they suggest anything beyond the brakebleeding
[Re: stumpy]
#2650439
04/30/19 08:11 AM
04/30/19 08:11 AM
Pyper70
Athens, Greece
Talked to the tech at Hydratech and he told me I still have air in the line somewhere, probably at the proportioning block...I have the car sitting at a 20 degree angle...hopefully the bubble will dislodge....going to push through another 1/2 gallon of fluid and then give it a good old fashion brake pedal bleed....He told me it will take about 150 miles for the steering system to clear out the micro bubbles and another 350 beyond that for the entire brake system to balance out. In the event that light doesn't go away, yeah...I'm pulling the pigtail from behind.
Right now when I step on the pedal it feels like an ABS pedal...which it shouldn't be. It has to feel like a manual brake pedal, firm.
