Can we talk big block truck headers again? #2649681
04/27/19 09:39 PM
04/27/19 09:39 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Anyone come across anything lately that fits the 4wd chassis that are 1 7/8 or 2" primary? I don't know if I am that crazy about fenderwell headers, I was looking at the fenderwell headers on a jeep at the 4wd store and the headers were pretty beat with crap flying off the tires. I want to run some larger heads on a stroker, choking it with 1 3/4's doesn't seem like a good plan.
Re: Can we talk big block truck headers again? [Re: Uberpube] #2649788
04/28/19 09:15 AM
04/28/19 09:15 AM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Did you check with Mad Dog Headers. They made them for 4x4 trucks.
Re: Can we talk big block truck headers again? [Re: 68dodge] #2649815
04/28/19 10:33 AM
04/28/19 10:33 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Yeah I looked at those, and also the reason I started looking at trucks with fenderwell headers to see how they survive. I supposed a stainless shield could be welded to the tubes in the well area to stop the crap from hitting the tubes, but not sure how it would look. I would prefer something that sat inside the frame rails.
Re: Can we talk big block truck headers again? [Re: Uberpube] #2651788
05/04/19 07:18 AM
05/04/19 07:18 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
What heads are you going to use that you need 2" primaries? What is the intended use of the truck?
Re: Can we talk big block truck headers again? [Re: redraptor] #2652060
05/05/19 12:54 AM
05/05/19 12:54 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Most likely the trick flow 270's on a 512 or 535. Truck will be a little of everything, some street, some mud slinging.
Re: Can we talk big block truck headers again? [Re: Uberpube] #2652093
05/05/19 07:41 AM
05/05/19 07:41 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Well, sounds like a custom headers to me to get everything you want. Maybe a set of A-body race headers and a weld-up kit to get them to fit how you want. shruggy
Re: Can we talk big block truck headers again? [Re: redraptor] #2652388
05/05/19 08:34 PM
05/05/19 08:34 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Yeah, I was thinking about that. If I recall correctly in the other thread, someone said the passenger side hits the drive shaft. But if the truck were lifted sufficiently , it may not be an issue.
Re: Can we talk big block truck headers again? [Re: Uberpube] #2652823
05/07/19 01:19 AM
05/07/19 01:19 AM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
They really aren’t that hard to make if you have a welder. Here are some that I made. They would be just as easy to route them inside the frame rails.
Re: Can we talk big block truck headers again? [Re: 6pakdakota] #2654158
05/10/19 08:39 PM
05/10/19 08:39 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Those look pretty good, did you start with a weld up kit and if so from where?
Re: Can we talk big block truck headers again? [Re: Uberpube] #2656468
05/18/19 06:18 AM
05/18/19 06:18 AM
Coastal Maine
Mr onetwo Offline
Mr onetwo  Offline
Coastal Maine
Check out these true Tri-Y's from Stans Headers.....not cheap, but super quality and fit like a glove. http://www.stans-headers.com/chrysler_headers.htm
Re: Can we talk big block truck headers again? [Re: Uberpube] #2656779
05/19/19 09:46 AM
05/19/19 09:46 AM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
Yes, I used two weld up kits from Summit Racing and I made the flanges myself.
