Re: Scrub from HS rockers on TrickFlow heads
[Re: Get-X]
#2648301
04/23/19 10:30 PM
04/23/19 10:30 PM
Posts: 614 Michigan
Get-X
If anyone can help with why the pics failed I'd appreciate it, lol.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: Get-X]
#2648309
04/23/19 11:00 PM
04/23/19 11:00 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Call Mike @ B3 racing, he makes custom offset correction spacers.
[Re: CSK]
#2648314
04/23/19 11:23 PM
04/23/19 11:23 PM
Posts: 4,457 Washington
madscientist
Washington
CSK nailed it. Stop screwing around and call Mike. You'll be glad you did. I can't see the pictures, but unless the sweep is .040 or a bit less, you need to fix the geometry. Centering the sweep if it's .080 or more wide doesn't mean a thing.
[Re: madscientist]
#2648325
04/24/19 12:42 AM
04/24/19 12:42 AM
Posts: 614 Michigan
Get-X
CSK nailed it. Stop screwing around and call Mike. You'll be glad you did. I can't see the pictures, but unless the sweep is .040 or a bit less, you need to fix the geometry. Centering the sweep if it's .080 or more wide doesn't mean a thing. Who's "screwing around"?? I spoke with Mike over a week ago and we had a very long discussion about this and lots of other things. He's a great guy and I really appreciated his time. That being said, I'll mock things up and look at them myself before I make any decisions. The scrub was .037 wide, .123 from the ex. side of the valve to .183 from the int. side on a .343 o.d. valve.
[Re: Get-X]
#2648436
04/24/19 11:44 AM
04/24/19 11:44 AM
Posts: 43,215 Bend,OR USA
Cab_Burge
CSK nailed it. Stop screwing around and call Mike. You'll be glad you did. I can't see the pictures, but unless the sweep is .040 or a bit less, you need to fix the geometry. Centering the sweep if it's .080 or more wide doesn't mean a thing. Who's "screwing around"?? I spoke with Mike over a week ago and we had a very long discussion about this and lots of other things. He's a great guy and I really appreciated his time. That being said, I'll mock things up and look at them myself before I make any decisions. The scrub was .037 wide, .123 from the ex. side of the valve to .183 from the int. side on a .343 o.d. valve. I'm glad to see others on here not drinking the cool aid on the rocker arm tip shrub patterns having to be no wider than .030 directly centered on the valve stem if it is centered, or almost centered and .060 wide I'll run that in a heartbeat
[Re: Get-X]
#2648442
04/24/19 12:05 PM
04/24/19 12:05 PM
madscientist
Washington
CSK nailed it. Stop screwing around and call Mike. You'll be glad you did. I can't see the pictures, but unless the sweep is .040 or a bit less, you need to fix the geometry. Centering the sweep if it's .080 or more wide doesn't mean a thing. Who's "screwing around"?? I spoke with Mike over a week ago and we had a very long discussion about this and lots of other things. He's a great guy and I really appreciated his time. That being said, I'll mock things up and look at them myself before I make any decisions. The scrub was .037 wide, .123 from the ex. side of the valve to .183 from the int. side on a .343 o.d. valve. Misread your post then. I couldn't see the pictures. Maybe if I had my response would have been different. If the sweep is that narrow, run it. Being centered doesn't mean a thing.
[Re: Cab_Burge]
#2648443
04/24/19 12:05 PM
04/24/19 12:05 PM
madscientist
Washington
CSK nailed it. Stop screwing around and call Mike. You'll be glad you did. I can't see the pictures, but unless the sweep is .040 or a bit less, you need to fix the geometry. Centering the sweep if it's .080 or more wide doesn't mean a thing. Who's "screwing around"?? I spoke with Mike over a week ago and we had a very long discussion about this and lots of other things. He's a great guy and I really appreciated his time. That being said, I'll mock things up and look at them myself before I make any decisions. The scrub was .037 wide, .123 from the ex. side of the valve to .183 from the int. side on a .343 o.d. valve. I'm glad to see others on here not drinking the cool aid on the rocker arm tip shrub patterns having to be no wider than .030 directly centered on the valve stem if it is centered, or almost centered and .060 wide I'll run that in a heartbeat .060 is too wide. Why leave it like that when it's fixable?
[Re: madscientist]
#2648461
04/24/19 01:27 PM
04/24/19 01:27 PM
Posts: 614 Michigan
Get-X
CSK nailed it. Stop screwing around and call Mike. You'll be glad you did. I can't see the pictures, but unless the sweep is .040 or a bit less, you need to fix the geometry. Centering the sweep if it's .080 or more wide doesn't mean a thing. Who's "screwing around"?? I spoke with Mike over a week ago and we had a very long discussion about this and lots of other things. He's a great guy and I really appreciated his time. That being said, I'll mock things up and look at them myself before I make any decisions. The scrub was .037 wide, .123 from the ex. side of the valve to .183 from the int. side on a .343 o.d. valve. Misread your post then. I couldn't see the pictures. Maybe if I had my response would have been different. If the sweep is that narrow, run it. Being centered doesn't mean a thing. All good man, I know you were just trying to help. Sadly I still haven't figured out why those pics won't show, LOL.
[Re: Get-X]
#2648588
04/24/19 07:54 PM
04/24/19 07:54 PM
Posts: 4,208 New York
polyspheric
New York
Centered" is at the bottom of the target list.
Boffin Emeritus
[Re: Get-X]
#2651370
05/02/19 09:30 PM
05/02/19 09:30 PM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
Note that Mancini's website lists the "E" version of Sharps (edelbrock) for Trick Flows too. Went through the same dilemma for my stealth heads. Switched to Edelbrock sharps, no fuss, no muss, no shims, no adapters, no BS. Just a good scrub pattern.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
[Re: 1KoolBee]
#2652609
05/06/19 01:14 PM
05/06/19 01:14 PM
Posts: 614 Michigan
Get-X
Note that Mancini's website lists the "E" version of Sharps (edelbrock) for Trick Flows too. Went through the same dilemma for my stealth heads. Switched to Edelbrock sharps, no fuss, no muss, no shims, no adapters, no BS. Just a good scrub pattern. Yep, we got back with HS and they were very kind in offering us an option to "swap" them his old rockers+ $$ and they're sending out the "E" rockers. They really owed us nothing, so they did it simply because they're a good company I guess? Either way hats off to HS for their awesome customer service.
[Re: Get-X]
#2653864
05/09/19 10:40 PM
05/09/19 10:40 PM
1KoolBee
Way North Idaho
That's awesome, glad it worked out. Shanon's worked a similar deal with HS for me. They're great to deal with.
