Milodon pan, qa1 k and Schumacher mounts #2648062
04/23/19 08:03 AM
04/23/19 08:03 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Finally got all the parts to put the engine in and the rr pan hits on the right side. K is centered, milodon says it's not a pan issue but a k issue. Oil pump also hits the k but not sure if it's related to not being able to level the engine. Just asking before i start cutting the pan up
Re: Milodon pan, qa1 k and Schumacher mounts [Re: buconine] #2648671
04/25/19 12:00 AM
04/25/19 12:00 AM
AndyF Online content
AndyF  Online Content
Not sure what your question is. Were you actually expecting a whole pile of aftermarket parts to fit together? On my car projects I spend 90% of the time trying to figure out how to get the new parts I just bought to fit and work.
Re: Milodon pan, qa1 k and Schumacher mounts [Re: AndyF] #2648748
04/25/19 10:18 AM
04/25/19 10:18 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Not realistic to expect it all to work together when none of it is oe. You introduced too many variables. See what the best avenue is to remedy the situation.
Carl Kessel
Re: Milodon pan, qa1 k and Schumacher mounts [Re: CKessel] #2648926
04/25/19 04:07 PM
04/25/19 04:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I suspect, based on the other Milodon thread, that if he was running the stock K member and it hit Milodon would blame the stock K member there too.
Whatever Milodon. Point is you're not going to get any love from them.
Don't be the exception.
Re: Milodon pan, qa1 k and Schumacher mounts [Re: AndyF] #2649483
04/27/19 08:12 AM
04/27/19 08:12 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
I was just seeing if anyone else had run into the same issue. I called milodon before ordering the pan and was told that the pan would work with my k member and that it "fit everything without issue." I knew doing the big block swap mounts was questionable with the qa1 k because i also called them and got "no clue, it's made for a small block." Guess i got spoiled doing drag cars because i never ran into these issues. Pan is off getting 3" chopped of the right side, left mounting pad has been modified for oil pump clearance. Hopefully it all goes back together smoothly
Re: Milodon pan, qa1 k and Schumacher mounts [Re: buconine] #2649579
04/27/19 03:55 PM
04/27/19 03:55 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I'm using that pan with the Indy aluminum block, Shumacher wedge to Hemi mounts on a 70 k-frame. No clearance issues.
Carl Kessel
Re: Milodon pan, qa1 k and Schumacher mounts [Re: buconine] #2649967
04/28/19 05:55 PM
04/28/19 05:55 PM
That road race pan is tight in any chassis. I've never seen one that went together easily, every one I've ever worked on has required at least some work to make it fit. In a couple of cases I just sold the pan and started over with something else.
Re: Milodon pan, qa1 k and Schumacher mounts [Re: AndyF] #2652063
05/05/19 01:03 AM
05/05/19 01:03 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I run those mounts and pan, stock kmember in my 71 runner - no issues with clearance
Re: Milodon pan, qa1 k and Schumacher mounts [Re: AndyF] #2652064
05/05/19 01:04 AM
05/05/19 01:04 AM
dangina Offline
dangina  Offline
there is so much truth to this its not even funny
