440 source aluminum heads? #2647632
04/21/19 08:45 PM
04/21/19 08:45 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Do you run the 440 source aluminum heads with the gold crane roller rockers? What push rod do you run? Thanks
Re: 440 source aluminum heads? [Re: bobs69] #2647639
04/21/19 09:25 PM
04/21/19 09:25 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I did. I used 3/8 pushrods because that's what I already had. They used to take a bunch of grinding with a burr to clear 3/8. I'd go with a custom 5/16 pushrods if you have to order anyway.
Re: 440 source aluminum heads? [Re: JAMESDART] #2647655
04/21/19 10:01 PM
04/21/19 10:01 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Not Crane gold but Crane ductile iron and Stealths. I measured with an adjustable pushrod and ordered thick wall 5/16 Manton's for clearance.
'63 Dodge 330
11.19 @ 121 mph
Re: 440 source aluminum heads? [Re: bobs69] #2647989
04/22/19 10:13 PM
04/22/19 10:13 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Get thick wall 5/16 pushrods from Manton or Smith Bros and save yourself alot of work grinding.
The only Carbs I care about are under the hood!
Re: 440 source aluminum heads? [Re: bobs69] #2647999
04/22/19 10:29 PM
04/22/19 10:29 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Stealth heads with Harlan Sharpe 1.6:1 rockers, about 0.600" lift with Hydraulic Roller cam.
Using Smith Brothers 5/16" diameter by 0.083" wall thickness pushrods.
https://docs.wixstatic.com/ugd/8060ba_77146955634f4d408019d085d342e4a5.pdf
Re: 440 source aluminum heads? [Re: bobs69] #2648051
04/23/19 05:44 AM
04/23/19 05:44 AM
PA
Harry's Taxi 2 Offline
PA
What type of cam are you going to use.....hyd., flat tappet or roller?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: 440 source aluminum heads? [Re: bobs69] #2648056
04/23/19 07:20 AM
04/23/19 07:20 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I run Mopar performance Part Number P4529560. I run a .590 solid cam with the crane golds. Did have to grind clearance for them though.
Re: 440 source aluminum heads? [Re: 451Mopar] #2650369
04/29/19 09:47 PM
04/29/19 09:47 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
After spending a lot of time and money fiddling around with Crane 1.5 Irons, 1.6 Irons, then regular 1.6 Harland Sharps on my 383/451's Stealth Heads, I found that the 1.6 Harland Sharps for Edelbrock heads (S70016KE) were the only ones that gave me correct valve tip geometry without any special shaft adapters, shims, or other high dollar geometry "fixes".. Once that was set, I ordered a set of Mantons at correct length and I was good to go. Nice narrow tip pattern in middle of valve stem with about .560 net lift. Also increased pushrod clearance a ton when compared to Irons. Shanon's hooked me up. They're not cheap but I wasted 2x the time and money screwing around with the other setups.
