Brake Bleeding
#2647300
04/20/19 04:01 PM
04/20/19 04:01 PM
Posts: 4,420 Michigan
MarkZ
Worthy
Worthy
Probably a rookie question....
I just got done plumbing a rear disc conversion on my car and it involved replacing the factory proportion valve with a distribution block. Since the lines were disconnected the master cylinder was drained. Is it necessary to bench bleed the master cylinder? I never removed it from the car. I've got a Mighty Vac and was just planning on bleeding all four corners one at a time starting with the closest wheel to the master cylinder and working my way out from there.
Thanks.
Re: Brake Bleeding
[Re: MarkZ]
#2647306
04/20/19 04:26 PM
04/20/19 04:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I probably is needed. I have a couple of short hard lines that screw into the M/C and loop back into the reservoir under the fluid level so that I can "bench bleed" the M/C in the car. Just go slow with the pedal or you will splash brake fluid.
Re: Brake Bleeding
[Re: MarkZ]
#2647323
04/20/19 05:19 PM
04/20/19 05:19 PM
Posts: 25,812 Rio Linda, CA
John_Kunkel
Rio Linda, CA
starting with the closest wheel to the master cylinder and working my way out from there. Start with the wheel farthest (right rear) from the MC.
Re: Brake Bleeding
[Re: John_Kunkel]
#2647372
04/20/19 08:05 PM
04/20/19 08:05 PM
RapidRobert
& put a block under the pedal so your helper dont go past the cups normal wear area & it helps him control the pedal travel better
