Carburetor Synchronizer/Manometer #2646867
04/19/19 02:54 PM
04/19/19 02:54 PM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Does anyone know where I can get a dual carb synchronizer, specifically for dual afb's? Dvorak Machine sells one, but I can't get a hold of them.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Carburetor Synchronizer/Manometer [Re: ChrgrCuda] #2646927
04/19/19 06:44 PM
04/19/19 06:44 PM
I bought one from Edlebrock years ago, call Summit and Jeg's and see if they stock them or not. scope
It should come with a adapter for smaller two barrel type carbs and for the early small AFB size air cleaner bases, You set one carb. at a time and set it up the way you want it and then make the other carb. match it wrench
Re: Carburetor Synchronizer/Manometer [Re: ChrgrCuda] #2646944
04/19/19 07:30 PM
04/19/19 07:30 PM
Minn
SportF Offline
SportF  Offline
Minn
When I was a kid I heard forever how hard it is to run multiple carbs. But, as an owner of a max wedge race car, and a street car running a max intake, I found this to be totally untrue. I have never "balanced" my carbs, and never had problems.
I do know that I have to set idle speed by going back and forth, but in the end, idle is set by only one carb, but it doesn't matter in performance I can tell. I suppose if I was running stock and needed every bit of performance I may care.
Re: Carburetor Synchronizer/Manometer [Re: SportF] #2646954
04/19/19 07:44 PM
04/19/19 07:44 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I bought mine from dvarak. You can do it with vacuum gauge.
Re: Carburetor Synchronizer/Manometer [Re: ChrgrCuda] #2646983
04/19/19 09:04 PM
04/19/19 09:04 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You can find them on ebay, you just have to go back and forth between carbs
Re: Carburetor Synchronizer/Manometer [Re: ChrgrCuda] #2647022
04/19/19 10:01 PM
04/19/19 10:01 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
https://www.amazon.com/s?k=motion+p...p;tag=mh0b-20&ref=pd_sl_3om86e2kwd_e
Motion pro makes them for motorcycle use,they have fluid filled manometer.Mine is an old mercury filled unit. Yu can also use multiple vacuum gauge sets.
Re: Carburetor Synchronizer/Manometer [Re: RTSrunner] #2647094
04/20/19 04:09 AM
04/20/19 04:09 AM
Ohio
lockjaw-express Offline
Ohio
Here is one for you...I made it, and works great!
BTW, I got the design off of the web somewhere...
Re: Carburetor Synchronizer/Manometer [Re: lockjaw-express] #2647113
04/20/19 08:37 AM
04/20/19 08:37 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Lockjaw do you have an Offenhauser dual quad there? Whats some specs of the car and engine? How does the manifold perform? Offenhauser is an interesting company.
Keep old mopars alive.
Re: Carburetor Synchronizer/Manometer [Re: 2boltmain] #2647121
04/20/19 08:59 AM
04/20/19 08:59 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree with no need for this tool. Been running dual carbs street car and racecar for over 25 years. Start with all 4 mixture screws the same number of turns and move all 4 the same amount.
Doug
Re: Carburetor Synchronizer/Manometer [Re: dvw] #2647142
04/20/19 09:50 AM
04/20/19 09:50 AM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Re: Carburetor Synchronizer/Manometer [Re: lockjaw-express] #2647180
04/20/19 10:43 AM
04/20/19 10:43 AM
moparx Offline
moparx  Offline
is that basic plastic plumbing pieces ? if so, what did you use ? i am not familiar with what plumbing parts are called. TIA ! up
beer
Re: Carburetor Synchronizer/Manometer [Re: dvw] #2647184
04/20/19 10:58 AM
04/20/19 10:58 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Doug
Different intakes will make carbs perform differently. The signal will be different from carb to carb.
Same intake with 2 different pairs of carbs will require a different tune.
These carb sync tools are a very valuable toll to tuning dual carbs.
As well as a single carb.
Re: Carburetor Synchronizer/Manometer [Re: lockjaw-express] #2647218
04/20/19 12:10 PM
04/20/19 12:10 PM
The tool on the top is what I have along with one cast aluminum reducer adapter up
As far as the Offy 360 dual carb intakes with dual carbs.on a wedge motor don't do that tsk The other dual plane dual quad intakes are way better than those old flat Offys twocents
Re: Carburetor Synchronizer/Manometer [Re: Sammy] #2647225
04/20/19 12:33 PM
04/20/19 12:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
So maybe we should build one that does all 8 individual throttle plates. Splitting hairs here.
Doug
Re: Carburetor Synchronizer/Manometer [Re: moparx] #2647377
04/20/19 08:25 PM
04/20/19 08:25 PM
Ohio
Ohio
Went to Fergussons Plumbing supply and bought the pieces. Just took a top ring gasket with me and this picture.
Also, bought the adjustable synchronizer off of ebay (popular item) for SU Carbs (British Carbs)...took that to the supply house too.
This is not my engine!
Mark
Re: Carburetor Synchronizer/Manometer [Re: lockjaw-express] #2647515
04/21/19 10:52 AM
04/21/19 10:52 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Manometer. Isn't that what Rosie O'Donell uses to pick out what she/it is going to wear? HA!
Carl Kessel
