A Body with B1BS heads?? #2645767
04/16/19 06:17 PM
04/16/19 06:17 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Has anyone ever used fender well headers with B1BS heads on a 1967 A body????/
T & K Performance
Re: A Body with B1BS heads?? [Re: ChevyTS] #2646552
04/18/19 05:49 PM
04/18/19 05:49 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Any Ideas guys?
T & K Performance
Re: A Body with B1BS heads?? [Re: ChevyTS] #2646557
04/18/19 06:01 PM
04/18/19 06:01 PM
God's Country Maryland
GODSCOUNTRY340 Offline
You would have to modify them to make them work. With the raised exhaust ports on B1 heads you'll have problems on the driver's side at the master cylinder and where they curl to turn back at the bottom. You'll have the same problem on the passenger side where they turn back. They are a tight fit even with factory heads.
Re: A Body with B1BS heads?? [Re: ChevyTS] #2646633
04/18/19 10:04 PM
04/18/19 10:04 PM
Which block, 361/400 low deck or a 413/440 high deck block?
Which brand fenderwell headers are you wanting to know about?
