Getting ready to paint mine and have read that the rally wheel silver is correct/close. Is the black supposed to flat or satin?
Rallye wheel silver(Argent) is as close as your going to get, I usually use satin black for the fin's backside (it's going to lose shine as it ages, as well as some dulling from over-spray as I'll explain) I spray the black first with the pcs standing vertical and the backside of the blade/fins facing upwards and only apply/spray paint in one direction, downward strokes/top to bottom, after the black drys, then rotate the pcs 180 degrees, again standing vertically, with the now painted black backsides of the fins facing downward, now apply the silver, again only spray from top to bottom, this way the paint "falls" in one direction only, if you've done it correctly the pcs will now be silver with just the backsides of the blades/fins having a black recess, use a spray gun rather than spray cans, as you'll have better control of the spray fan width, and you'll use better quality mat'ls, and you'll have a better professional finish in the end
Mike
