94 Chrysler Concorde? #2645413
04/15/19 02:54 PM
04/15/19 02:54 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Battery went dead, there is a 4 volt draw on the battery with the ignition off. Where to begin looking for the cause.
Charges at 15 volts, battery is good. ??? Thanks in advance.
Larry
Re: 94 Chrysler Concorde? [Re: MO_PA] #2645470
04/15/19 06:00 PM
04/15/19 06:00 PM
Sudbury, ontario canada
750-h2 Offline
750-h2  Offline
Pull out one fuse at a time until you find where the draw is coming from.
Re: 94 Chrysler Concorde? [Re: MO_PA] #2645478
04/15/19 06:36 PM
04/15/19 06:36 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Drove a 2000 intrepid for years without issue. Found out that if it sat for a week, the batt would suffer. It had a draw alright, you might want to check into the security/factory 240 watt circuit on that thing if it's loaded.
Re: 94 Chrysler Concorde? [Re: buildanother] #2645480
04/15/19 06:44 PM
04/15/19 06:44 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thanks guys, I pulled all the fuses in the box under the hood, I'll go inside the car tomorrow.
It has the 'super security' system. A bunny spent part of the winter under the hood and chewed
insulation off the hot wire to the air condition compressor...little sh(t.
