Re: Bent pushrod problem?
[Re: MR_P_BODY]
#2644689
04/13/19 11:06 AM
04/13/19 11:06 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Did you ever have the motor or car on the dyno?
If not, I’d suggest you do......... see if you can nail down when the valve float/lifter unhappiness occurs, and keep the motor below that point. With a hyd roller(or hyd flat tappet)....... it often occurs at a lower rpm than you might suspect.
Running the motor up into the rpm range where things get unhappy usually results in things happening like what you’re experiencing.
[Re: plumcrazycuda]
#2644711
04/13/19 11:51 AM
04/13/19 11:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I wouldnt double nut them.. 19 years is pretty damn good for not having the valve covers off.. you dont need the extra weight on the valve train.. you can buy a pair of rockers .. they have a tie bar for each pair
[Re: plumcrazycuda]
#2644712
04/13/19 11:54 AM
04/13/19 11:54 AM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of these cameras that hook up to your phone or laptop send pretty clear pictures and are really cheap now. It could save you some time and money and answer all you questions.
[Re: pittsburghracer]
#2644717
04/13/19 12:07 PM
04/13/19 12:07 PM
MR_P_BODY
Some of these cameras that hook up to your phone or laptop send pretty clear pictures and are really cheap now. It could save you some time and money and answer all you questions. I have one but its a stand alone unit.. I can put it down a spark plug hole to see in cylinders or any place that bigger than 13mm in dia.. works nice and was pretty cheap
[Re: MR_P_BODY]
#2644721
04/13/19 12:17 PM
04/13/19 12:17 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of these cameras that hook up to your phone or laptop send pretty clear pictures and are really cheap now. It could save you some time and money and answer all you questions. I have one but its a stand alone unit.. I can put it down a spark plug hole to see in cylinders or any place that bigger than 13mm in dia.. works nice and was pretty cheap I'm thinking with the valve cover off he could sneak it down in the valley and see everything.
#2644723
04/13/19 12:31 PM
04/13/19 12:31 PM
fast68plymouth
So. Burlington, Vt.
Good luck trying to find lifters that are the same as what you bought 19 years ago.
#2644730
04/13/19 12:56 PM
04/13/19 12:56 PM
MR_P_BODY
Some of these cameras that hook up to your phone or laptop send pretty clear pictures and are really cheap now. It could save you some time and money and answer all you questions. I have one but its a stand alone unit.. I can put it down a spark plug hole to see in cylinders or any place that bigger than 13mm in dia.. works nice and was pretty cheap I'm thinking with the valve cover off he could sneak it down in the valley and see everything. Yeah I know what you were getting at
[Re: fast68plymouth]
#2644751
04/13/19 02:02 PM
04/13/19 02:02 PM
Posts: 1,747 PA
plumcrazycuda
PA
Good luck trying to find lifters that are the same as what you bought 19 years ago. I looked the part number up and they are still available. You wouldn’t think they would be different and have the same part number. I don’t care about a little weight on the valve train,I don’t want them to come loose again. I think the last time I had them off was 2001. I don’t drive it much at all. Maybe 1k a year but back in the early 2000 it was my only Cuda so it got out more back then and that when I raced it!
[Re: plumcrazycuda]
#2644753
04/13/19 02:14 PM
04/13/19 02:14 PM
MR_P_BODY
Crane was bought out sometime back.. its hard to say for fact if they are truely the same without a call or measuring them.. also being that you are running a hyd roller your springs would be pretty weak and adding any weight would be a challenge to your springs.. but ask around
[Re: MR_P_BODY]
#2644773
04/13/19 04:17 PM
04/13/19 04:17 PM
Posts: 1,747 PA
plumcrazycuda
PA
Crane was bought out sometime back.. its hard to say for fact if they are truely the same without a call or measuring them.. also being that you are running a hyd roller your springs would be pretty weak and adding any weight would be a challenge to your springs.. but ask around You may be on to something here. I will see if my springs are to heavy for a roller. I still have my paperwork from when I had my heads done. They are Crane springs part number 99098.
[Re: plumcrazycuda]
#2644983
04/14/19 11:27 AM
04/14/19 11:27 AM
fast68plymouth
So. Burlington, Vt.
19 years ago Crane made their own roller lifters in house.
They have been sold at least 3 times since then, and have not had lifter manufacturing capabilities for quite a while.
#2644993
04/14/19 11:45 AM
04/14/19 11:45 AM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My friends and I took a tour of the crane facility back in the 1970’s while on a vacation. There was a little old lady straightening pushrods with a hammer and dial indicator. Lol
#2645014
04/14/19 12:27 PM
04/14/19 12:27 PM
fast68plymouth
So. Burlington, Vt.
They are Crane springs part number 99098. 99098 is the part number for 3/8 7* valve locks.
#2645041
04/14/19 02:13 PM
04/14/19 02:13 PM
Posts: 1,747 PA
plumcrazycuda
PA
They are Crane springs part number 99098. 99098 is the part number for 3/8 7* valve locks. I was looking at the wrong part number. Thanks for letting me know! The spring part number is 99890
