Bent pushrod problem? #2644563
04/12/19 10:48 PM
04/12/19 10:48 PM
PA
P
plumcrazycuda Offline OP
P
PA
This motor been together for 19 years with hundreds of trips down the quarter mile and thousands miles on the street.
This spring I took it out to get some fuel moving and one of the adjustable rocks came loose and the pushrod was just laying in there.
The pushrod beside it was the bent one. I don’t know but think the loose pushrod some how bent the one next to it. Don’t think the valve is bent but will check it. What’s your thoughts on this?
Re: Bent pushrod problem? [Re: plumcrazycuda] #2644573
04/12/19 11:16 PM
04/12/19 11:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check your valve springs to see if you have a few weak ones
wave
Re: Bent pushrod problem? [Re: plumcrazycuda] #2644580
04/12/19 11:27 PM
04/12/19 11:27 PM
The loose adjuster allowed the loose pushrod to fall into the motor bending the other pushrod shruggy scope
I've had that happen also whiney shruggy
Re: Bent pushrod problem? [Re: Cab_Burge] #2644655
04/13/19 10:02 AM
04/13/19 10:02 AM
PA
P
P
PA
Ok this is a hydraulic roller. Could this damage the lifter? I had adjustable rocker problem in the past and also had the lifter top break off a took my cam out. Back then there was a adjuster heat treatment problem. The adjuster kept breaking. They warranty the cam and lifters. I only ran it about a mile to get it home this time. Am I just gun shy or should I pull intake off and look at the lifter for cracks?
Re: Bent pushrod problem? [Re: plumcrazycuda] #2644671
04/13/19 10:39 AM
04/13/19 10:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It could damage the cam or the lifter.. to be safe I would pull the intake
just to be sure
wave
Re: Bent pushrod problem? [Re: MR_P_BODY] #2644689
04/13/19 11:06 AM
04/13/19 11:06 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Did you ever have the motor or car on the dyno?
If not, I’d suggest you do......... see if you can nail down when the valve float/lifter unhappiness occurs, and keep the motor below that point.
With a hyd roller(or hyd flat tappet)....... it often occurs at a lower rpm than you might suspect.
Running the motor up into the rpm range where things get unhappy usually results in things happening like what you’re experiencing.
Re: Bent pushrod problem? [Re: fast68plymouth] #2644702
04/13/19 11:32 AM
04/13/19 11:32 AM
PA
P
P
PA
For some reasons the lock nut came loose on the rocker. This is why the pushrod came out. Don’t know why after so long that the nut broke loose? I only ran it up to like 4K rpm and it pull hard to 6500+but to be honest I have not run it at the track for years. I had two pushrod and put them in today and it fired right up!
I am going to pull the intake and would like to replace that lifter if I can get just one form Crane cam. Don’t want to buy 8 of them to get one. I would sleep better if I can replace it! I am going to double nut the adjuster bolt. Don’t want to have it happen again and don’t want to lose my motor over it! I know one thing for sure if the lifter breaks it over quick!
Re: Bent pushrod problem? [Re: plumcrazycuda] #2644711
04/13/19 11:51 AM
04/13/19 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt double nut them.. 19 years is pretty damn good for not having
the valve covers off.. you dont need the extra weight on the valve train..
you can buy a pair of rockers .. they have a tie bar for each pair
wave
Re: Bent pushrod problem? [Re: plumcrazycuda] #2644712
04/13/19 11:54 AM
04/13/19 11:54 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Some of these cameras that hook up to your phone or laptop send pretty clear pictures and are really cheap now. It could save you some time and money and answer all you questions.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Bent pushrod problem? [Re: pittsburghracer] #2644717
04/13/19 12:07 PM
04/13/19 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have one but its a stand alone unit.. I can put it down a spark plug hole
to see in cylinders or any place that bigger than 13mm in dia.. works nice
and was pretty cheap
wave
Re: Bent pushrod problem? [Re: MR_P_BODY] #2644721
04/13/19 12:17 PM
04/13/19 12:17 PM
PA.
"Little"John
"Little"John
PA.
wave
I'm thinking with the valve cover off he could sneak it down in the valley and see everything.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Bent pushrod problem? [Re: pittsburghracer] #2644723
04/13/19 12:31 PM
04/13/19 12:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
Good luck trying to find lifters that are the same as what you bought 19 years ago.
Re: Bent pushrod problem? [Re: pittsburghracer] #2644730
04/13/19 12:56 PM
04/13/19 12:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Yeah I know what you were getting at
Re: Bent pushrod problem? [Re: fast68plymouth] #2644751
04/13/19 02:02 PM
04/13/19 02:02 PM
PA
P
P
PA
I looked the part number up and they are still available. You wouldn’t think they would be different and have the same part number.
I don’t care about a little weight on the valve train,I don’t want them to come loose again. I think the last time I had them off was 2001. I don’t drive it much at all. Maybe 1k a year but back in the early 2000 it was my only Cuda so it got out more back then and that when I raced it!
Re: Bent pushrod problem? [Re: plumcrazycuda] #2644753
04/13/19 02:14 PM
04/13/19 02:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Crane was bought out sometime back.. its hard to say for fact if they
are truely the same without a call or measuring them.. also being that
you are running a hyd roller your springs would be pretty weak and
adding any weight would be a challenge to your springs.. but ask
around
wave
Re: Bent pushrod problem? [Re: MR_P_BODY] #2644773
04/13/19 04:17 PM
04/13/19 04:17 PM
PA
P
P
PA
around
wave
You may be on to something here. I will see if my springs are to heavy for a roller. I still have my paperwork from when I had my heads done. They are Crane springs part number 99098.
Re: Bent pushrod problem? [Re: plumcrazycuda] #2644983
04/14/19 11:27 AM
04/14/19 11:27 AM
So. Burlington, Vt.
So. Burlington, Vt.
19 years ago Crane made their own roller lifters in house.
They have been sold at least 3 times since then, and have not had lifter manufacturing capabilities for quite a while.
Re: Bent pushrod problem? [Re: fast68plymouth] #2644993
04/14/19 11:45 AM
04/14/19 11:45 AM
PA.
"Little"John
"Little"John
PA.
My friends and I took a tour of the crane facility back in the 1970’s while on a vacation. There was a little old lady straightening pushrods with a hammer and dial indicator. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Bent pushrod problem? [Re: pittsburghracer] #2645014
04/14/19 12:27 PM
04/14/19 12:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
99098 is the part number for 3/8 7* valve locks.
Re: Bent pushrod problem? [Re: fast68plymouth] #2645041
04/14/19 02:13 PM
04/14/19 02:13 PM
PA
P
P
PA
Quote
I was looking at the wrong part number. Thanks for letting me know! The spring part number is 99890
