Re: Dare I say. Too much go!
[Re: Montclaire]
#2644539
04/12/19 09:12 PM
04/12/19 09:12 PM
Posts: 855 ontario canada kingston
aspenrt360
Yeah binding cable perhaps.. weak spring or i have had the kickdown arm rub the bottom of a drop base air cleaner too.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
[Re: aspenrt360]
#2644547
04/12/19 09:30 PM
04/12/19 09:30 PM
Garry Owen
Yeah binding cable perhaps.. weak spring or i have had the kickdown arm rub the bottom of a drop base air cleaner too. Did it again without air cleaner. Spent 15 minutes in neutral revving without binding. Has 3 springs on it, it’s got a solid return. I’ll order a new throttle cable just in case. I’m still stumped and now I have to fix the paint from hitting a welding cart before I got it shut down while putting it gear. Yes, I’m a dumba** for doing it in the shop. Maybe I’ll order a cable kick down too. It has a rod style setup now. I didn’t get it to bind but maybe
[Re: moparx]
#2644718
04/13/19 12:11 PM
04/13/19 12:11 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Unhook the pcv line from the carb, plug the port. Try it again.
Power brakes? Could be a leaky diaphragm.
If it has really weak springs in the distributor, it might just have so much timing it’s keeping the rpm up.
[Re: Garry Owen]
#2644804
04/13/19 07:34 PM
04/13/19 07:34 PM
Posts: 15,429 Omaha Ne
TJP
Omaha Ne
Have you tried driving it without the air cleaner ? Also make sure there is a bit of slack in the accelerator cable when idling warm off choke Speaking of chokes, any chance the fast idle cam is activating??
[Re: SpeedThrills]
#2645002
04/14/19 11:54 AM
04/14/19 11:54 AM
Garry Owen
Fast68, Unhook the pcv line from the carb, plug the port. Try it again. ok, maybe too much vacuum?
Power brakes? Could be a leaky diaphragm. yes, I’ll check
If it has really weak springs in the distributor, it might just have so much timing it’s keeping the rpm up. I’ll see what’s in it
TJP, Have you tried driving it without the air cleaner ? yes, no change.
Also make sure there is a bit of slack in the accelerator cable when idling warm off choke there is
Speaking of chokes, any chance the fast idle cam is activating?? I’ll check
Stumpy, Might want to check out the motor mounts to be sure the motor isn't torqueing over putting things in a bind. should have bound while still in park though, right?
