Re: Who makes custom head gaskets - besides Cometic?
[Re: Stanton]
#2646847
04/19/19 01:51 PM
04/19/19 01:51 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Try FLATOUT GASKETS.. owner Mark Adellizzi... past Fel-Pro engineering background ... I worked with him for many years... great guy! http://www.flatoutgroup.comBUT... as surface finish is a problem of concern for metal faced gaskets (ie: MLS, copper, etc), why don't you just use the Fel-Pro Performanc BB head gasket #1009... fiber faced, ant-istick coatings, with stainless steel armor that warps around an internal pre-compressed wire ring... this is bullet proof... long lasting and race proven! The internal wire ring is the same concept/design as commonly used for diesel engines (with high CR such as 16-21 and up).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2646891
04/19/19 04:08 PM
04/19/19 04:08 PM
Posts: 8,869 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
BUT... as surface finish is a problem of concern for metal faced gaskets (ie: MLS, copper, etc), why don't you just use the Fel-Pro Performanc BB head gasket #1009... fiber faced, ant-istick coatings, with stainless steel armor that warps around an internal pre-compressed wire ring... this is bullet proof... long lasting and race proven! The internal wire ring is the same concept/design as commonly used for diesel engines (with high CR such as 16-21 and up). Because NOBODY makes that style of gasket thick enough for my purpose. The thickest is Felpro at .052. I need .062 or ideally .067
[Re: Twostick]
#2647172
04/20/19 10:31 AM
04/20/19 10:31 AM
RapidRobert
Kevin what is the best sealer for em (I have a pair).
[Re: RapidRobert]
#2647198
04/20/19 11:21 AM
04/20/19 11:21 AM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin what is the best sealer for em (I have a pair). I would think any brand name type ie Permatex or equivalent. You're just sealing water not compression Kevin
[Re: Twostick]
#2647237
04/20/19 01:08 PM
04/20/19 01:08 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
How close to the correct finish are you? Who the hell knows ... without the tool to measure RA its a guess. BUT I did watch a video about head gaskets and deck finishes and I don't think its smooth enough. Even the machine shop says its not smooth enough for MLS gaskets.
