Re: 70 HP440 six pack Balancer Question
[Re: moparpoolman]
#2643141
04/09/19 10:00 AM
04/09/19 10:00 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
The "six pack" rods are heavier so those motors are externally balanced. They use the special weighted balancer and a weighted torque converter. If you change rods, then the assembly needs rebalancing and ideally you'd change it to internal balance at that time. Use a neutral balancer and converter. You can remove the weights from the stock converter. Internally balancing makes everything easier...no worrying about weighted converters or special scallop cut flexplates.
Unless you want the 100% correct resto look, internal balance is the way to go.
[Re: an8sec70cuda]
#2643161
04/09/19 10:33 AM
04/09/19 10:33 AM
Posts: 10,719 North Dakota
6PakBee
North Dakota
I'd recommend you read through this. Dampers
[Re: moparpoolman]
#2643235
04/09/19 01:26 PM
04/09/19 01:26 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
see what an8secCuda says.
The forged 440 crankshafts are all the same, except "I think" the six packs got a .001" surface hardening (which will be gone when polished or turned, so don't worry about it). The rods are heavier, that's it. The dampener & flywheel/torque converter weights balance out the heavier rods.
For your '70 steel crank, I suggest you buy a new, neutral balanced harmonic balancer (dampener) and neutral balance the engine with the eagle rods. Also, neutral balance your torque converter or flywheel/clutch (separately) too. This makes changing out those parts in the future MUCH easier.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: moparpoolman]
#2643302
04/09/19 04:27 PM
04/09/19 04:27 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The rod and piston weight require the external balance, the lighter '72-later piston didn't need external balance with the heavy rods.
