8.25 Rear End Pinion 74 Satellite
#2642593
04/08/19 07:58 AM
04/08/19 07:58 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
1974 Satellite Sebring. Was changing rear yoke and U-Joint. While the yoke was out, I grabbed the pinion. It had noticeable side to side movement. I did not measure, but 1/16 to 1/8 of inch is what it felt like. Is this normal? I have not done anything with a pinion bearing before and do not know the adjustments.
I know this car eats U-Joints, just wondering if this could be part of the problem.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: 8.25 Rear End Pinion 74 Satellite
[Re: buildanother]
#2642661
04/08/19 11:00 AM
04/08/19 11:00 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You do know that the pinion sets the preload and when you remove the yoke you are supposed to use a new crush sleeve and go thru the preload setup.
Anyway, without the yoke in place you will have excessive movement of the pinion. How much? Dunno never really paid attention to that.
[Re: Supercuda]
#2643106
04/09/19 08:25 AM
04/09/19 08:25 AM
70Coronet500Vert
St Charles MO
yep. Just never opened one before and was surprised at how much it moved.
