Power windows #2642723
04/08/19 12:48 PM
04/08/19 12:48 PM
Vancouver,BC
Mopar300F Offline OP
Vancouver,BC
I have a 68 Charger with power windows, the drivers side door window will not work at the master or singe switch. The motor is fine as I have been able to raise and lower it by a direct connection but not through the switch. Any ideas where to look for the source of the problem. All other windows work.
Paul
Re: Power windows [Re: Mopar300F] #2642739
04/08/19 01:26 PM
04/08/19 01:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well, that's the window that gets the most use, so I'd suspect worn contacts at the switch.
LF door should only have the 4-gang switch, not sure what single switch you'd be referring to.
Re: Power windows [Re: topside] #2642742
04/08/19 01:35 PM
04/08/19 01:35 PM
Vancouver,BC
Vancouver,BC
My mistake, its the passenger door window that will not work.
Re: Power windows [Re: Mopar300F] #2642749
04/08/19 01:49 PM
04/08/19 01:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Everything goes to the master before it goes to the single switches.
A meter and the diagrams out of the FSM will help you narrow it down.
http://www.mymopar.com/index.php?pid=27
Don't be the exception.
Re: Power windows [Re: Mopar300F] #2642750
04/08/19 01:51 PM
04/08/19 01:51 PM
Mass
charge70 Offline
charge70  Offline
Mass
If the master switch is bad the windows will not operate from the single switch on the door or the rear 1/4's.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
