Re: 72-up Big Block Truck Motor mounts
[Re: moparmarks]
#2642853
04/08/19 05:03 PM
04/08/19 05:03 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Thanks Mark these look like a variation of the top right 4 wheel drive ones... They do. Does the left side have a hole to clear the oil pump pressure spring nut? No hole it's solid there...
[Re: QuickBpBp]
#2643218
04/09/19 12:45 PM
04/09/19 12:45 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
This is just from memory, a long time ago I bought a set of brackets from a big block van, and it seems like they looked like that. I wound up buying the correct brackets new at the dealership. That should give an idea how long ago it was... P.S. I was putting a 383 in a 2WD 73 Club Cab.
[Re: Jwilli500]
#2643336
04/09/19 05:42 PM
04/09/19 05:42 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
The engine came out of a 78 truck or ram charger it was in and running so should not be from a van.. Just trying to figure out whether 4 wheel drive or not. I am surprised people can identify for sure as I thought guys were messing with these old trucks...
[Re: poorboy]
#2643698
04/10/19 02:41 PM
04/10/19 02:41 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I am trying to remember now. This was back in the 90's. My buddy bought a running/driving 76sh Dodge camper van with a 440. We pulled the engine from the van and dropped it right into his 83 D150 2WD pick up truck with headers. I don't remember needing or getting any different engine mount brackets. We had it going in the new truck the same day. I do remember grinding a radius in the driver side frame rail rather than ding the header tube. Man, did that truck fly...
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: SattyNoCar]
#2643738
04/10/19 04:48 PM
04/10/19 04:48 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I had a (factory) big block (2wd) '77 truck 25 yrs ago. It's been my understanding that when the brackets are shaped like yours, they're for 4 wheel drive. When they are straight like pictured below, they are for two wheel drive (this is what my truck had). I hope these are right, as I bought a set of those as well as ram horn manifolds and a water pump to put a big block in my '78.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2643887
04/10/19 10:16 PM
04/10/19 10:16 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I had a (factory) big block (2wd) '77 truck 25 yrs ago. It's been my understanding that when the brackets are shaped like yours, they're for 4 wheel drive. When they are straight like pictured below, they are for two wheel drive (this is what my truck had). I hope tpighese are right, as I bought a set of those as well as ram horn manifolds and a water pump to put a big block in my '78. If 2wd yes
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Mr onetwo]
#2644197
04/11/19 09:46 PM
04/11/19 09:46 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
These photos are off my totally stock 78 Ramcharger SE 440....hope they help Thanks! That is them and the engine was a 78 these came from. They are identical. I guess now the next question... Is your Ramcharger 4 wheel drive? Thanks again!
