Progressive linkage, is there a Right way? #2642276
04/07/19 01:00 PM
04/07/19 01:00 PM
Aubigny, MB Canada
69 F5 R/T Offline OP
Aubigny, MB Canada
Installing the progressive linkage on bros GTX and it seems to me you would attach to rear carb and set it to open front on the slide. Looking around I see it both ways and about 50/50 one way or the other.
Is this because of space constraints or?
Is there a preferred way it was intended to be installed, or does is basically operate the same regardless? (just personal preference)
Bringin Back the Iron!
Re: Progressive linkage, is there a Right way? [Re: 69 F5 R/T] #2642290
04/07/19 01:26 PM
04/07/19 01:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You will get as many no's as yes's,here is one "supposedly" not messed with.
Re: Progressive linkage, is there a Right way? [Re: 69 F5 R/T] #2642311
04/07/19 02:47 PM
04/07/19 02:47 PM
AndyF Offline
AndyF  Offline
Doesn't the FSM show how to install it?
Re: Progressive linkage, is there a Right way? [Re: AndyF] #2642326
04/07/19 03:16 PM
04/07/19 03:16 PM
Aubigny, MB Canada
Aubigny, MB Canada
68 manual shows slide on front carb. I will check 70.....
Re: Progressive linkage, is there a Right way? [Re: 69 F5 R/T] #2642692
04/08/19 11:53 AM
04/08/19 11:53 AM
Aubigny, MB Canada
Aubigny, MB Canada
Yeah 70 is the same, so hooked it up that way.
Funny, I've read all kinds of posts on setting the progressive linkage and adjusting so front carb comes in where you want it to.
from what I can see, there is no adjustment like that. If you try to make front carb come on sooner, you will lose FULL throttle/ WOT on both carbs.(ie. you will never get Both carbs WOT together)
Only way to set it AFAIK is to both carbs WOT like manual says.
Someone correct me if I'm missing something here : )
