Name and part # torsion bar bushing help #2636100
03/23/19 07:48 PM
03/23/19 07:48 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Can you please help me identify the specific name of this bushing and or part #? I just need these not an entire kit. Thanks
Its for a 68 Dodge Dart**
Re: Name and part # torsion bar bushing help [Re: WS68SSC] #2636104
03/23/19 08:01 PM
03/23/19 08:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
strut rod bushing. now you need to decide on rubber or poly?
Re: Name and part # torsion bar bushing help [Re: WS68SSC] #2636234
03/24/19 12:41 AM
03/24/19 12:41 AM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The pictured bushing is the "improved" style. Originals are one-piece.
https://www.moog-suspension-parts.com/moog-k7040
Re: Name and part # torsion bar bushing help [Re: John_Kunkel] #2636327
03/24/19 10:58 AM
03/24/19 10:58 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Shouldn't the cupped washer be facing the opposite way in he pic?
Joe
Re: Name and part # torsion bar bushing help [Re: jlatessa] #2636528
03/24/19 04:43 PM
03/24/19 04:43 PM
Rio Linda, CA
Rio Linda, CA
No, that version of the bushings has the cup facing outward.
Re: Name and part # torsion bar bushing help [Re: WS68SSC] #2638170
03/28/19 04:55 PM
03/28/19 04:55 PM
K
karengarneau Offline
K
I used the one piece replacement strut rod bushing. Some people might not like the idea of using a GM parts supplying for mopar but here it is....
ACDelco part # 45G25010
one per box
got them at Rock Auto
$6 each IIRC
made in the USA
Work fine in my A-Bodies
Bennoel
Re: Name and part # torsion bar bushing help [Re: karengarneau] #2638179
03/28/19 05:14 PM
03/28/19 05:14 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
Moog K7040 is the improved strut rod bushing kit for the 68 , just put a set on a 68 Cuda, next set is going on a 68 Dart
Re: Name and part # torsion bar bushing help [Re: Hemidavey] #2638241
03/28/19 08:21 PM
03/28/19 08:21 PM
K
K
Used those Moog bushings also.
Had a negative out come.
First of all I found them too thick and I believe they tend to push back towards the rear of the car on the LCA's
After approx 10,000 miles started to feel/hear a clunking noise when applying the brakes. After looking around discovered that the bushings were breaking apart/crumbling. As a result I found the one piece bushings and so far no issue. ( Two seasons and lots of miles). Hopefully this is the last time I will replace.
I believe that the one piece bushings are correct for the a body.
Just my opinion and we all have one. LOL
Re: Name and part # torsion bar bushing help [Re: karengarneau] #2641836
04/06/19 07:42 AM
04/06/19 07:42 AM
Australia
charger RTSE Offline
Australia
Yes same thing to me with the Moog clunk noise braking when car would finish braking and move back, took me some time to work it out the metal piece in the bush was cracked.
Re: Name and part # torsion bar bushing help [Re: charger RTSE] #2641998
04/06/19 02:56 PM
04/06/19 02:56 PM
BDW Offline
BDW  Offline
Originally Posted by charger RTSE
[quote=bennoel]
I have a clunking noise I can’t pin down. Any more details on this?
Re: Name and part # torsion bar bushing help [Re: BDW] #2642143
04/07/19 12:26 AM
04/07/19 12:26 AM
Australia
Australia
If you have the moog improved strut bush get rid of them. You could try and tighten up the front strut bolt some more.
Re: Name and part # torsion bar bushing help [Re: BDW] #2642227
04/07/19 10:17 AM
04/07/19 10:17 AM
K
K
[quote=bennoel]
I was referring to a-body strut rod bushings as they are a one piece bushing originally from the factory. I came to the conclusion that the two piece replacement bushing is too thick. I also believe as a result of the improper size it puts pressure on the LCA towards the rear. I don't think this can be good for the LCA bushings either because if I'm correct its as if the strut rod is now too long. Just my opinion. Hope this helps
