99 durango 5.9 converter problem #264156
03/24/09 02:19 AM
03/24/09 02:19 AM
Columbus Ga
reflections7 Offline OP
Columbus Ga
whats the fix for a converter in a 99 Durango that at 45-50 locks up and then unlocks back and forth alot. it just started. speed up and it quits.
Again it just started. its not overdrive it only changes about 200 rpm.
Re: 99 durango 5.9 converter problem [Re: reflections7] #264157
03/24/09 07:01 AM
03/24/09 07:01 AM
Southeast MI
ARETEE Offline
ARETEE  Offline
Southeast MI
Replace your TPS ( throttle position sensor )
Maybe $50 - $60 at the dealer, your converter problem will be solved...
