Edit: 727 is out and apart- here’s what I found #2638321
03/29/19 01:16 AM
03/29/19 01:16 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Howdy fellas
I’m getting a little more seat time in my hotrod and it’s becoming obvious that something isn’t right in my transmission. If you didn’t see my earlier thread I couldn’t get any gear at first because I had installed the pickup/ filter extension for the deep pan 180° out and wasn’t building line pressure.
I’m a little bummed I have more work to do but doing it is the best way to learn right? I’m hoping I can describe my symptoms and say what I’m thinking based on my very limited understanding of the 727, and get confirmation or correction & guidance from all you 727 experts.
-atf level good
-shifter synchronized/indexed properly
-cable style theottle pressure lever adjusted for WOT and fitted with a return spring
-tf2 kit installed
-2400 holeshot converter
-1 manual works great
-2 manual same
-D shifts quickly through 1-2 at low throttle, hangs on to 1 longer with more gas, never seems to shift into 3rd/direct
-R sometimes shifts and works good, sometimes acts like neutral, sometimes bang bang bang jerks you backward hard and shudders
I’m not sure if I ever had 3rd or not but it just never seems to go into cruising gear. I have a 512 motor and 3.21 sure grip so second gear will do 60mph pretty easy. Around my neighborhood and some bigger streets it does a really nice footbrake burnout (instant smoke) and breaks loose the tires at 30mph if I mash it a little. So I guess it must have some pressure and the rear clutches working?
So since the front clutch seems to be the one thing that reverse and 3rd have in common, and reverse has a mich higher line pressure, I’m thinking the piston is not sealing? Or something is amiss there.
Should I go ahead and buy some pressure gauges? What is an affordable option and do I have ro cobble together a 727 tool or two with hoses long enough to see from safely not under the car? 100 & 300 psi guages right? Links or advice mich appreciated.
Should I assume that it is the front clutch that is causing this or is it possible that the problem is in my valve body- possibly a swapped or backward shaft or a check ball causing this? Band adjustment?
Should I go straight to an air check on the front clutch? What am I looking for and am I on the right track trying to fix it?
If I keep finding problems I’m really gonna be an expert soon haha
Thanks for y’alls time and patience
Radar
Re: More 727 trans problems from dum-dum [Re: radar] #2638335
03/29/19 05:32 AM
03/29/19 05:32 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Air check the front clutch. If I were a betting man I'd say you tore the outer piston seal on installation. Did you have trouble getting the piston to drop into the drum?
Doug
Re: More 727 trans problems from dum-dum [Re: radar] #2638403
03/29/19 09:22 AM
03/29/19 09:22 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
In these cases where a shift kit has been installed and not already tested, I always recommend installing a known good unmolested valve body. That is about the easiest and cheapest test before you pull the tranny. Of course, valve bodies used to be everywhere. That is not true anymore.
And you can air check the front clutch at the same time.
Master, again and still
Re: More 727 trans problems from dum-dum [Re: DaveRS23] #2638468
03/29/19 01:10 PM
03/29/19 01:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If it stays in 2nd, it's a possible control/kickdown/governor/VB problem, i.e. the 2nd gear servo is staying on. If it goes into a false neutral and freewheels instead of going into high, then it's the front clutch not applying. But, since reverse is also not right, you are correct that the high clutch is the common element. Multiple things going on. A pressure check of different functions would help. Or as suggested, swapping in a known good VB would confirm or rule out all of the issues being valve body related. Band adjustments also need to be verified.
Re: More 727 trans problems from dum-dum [Re: radar] #2638492
03/29/19 02:25 PM
03/29/19 02:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When in doubt if it's in 3rd gear, throttle back to idle and shift to 2nd...if it noses over it was in 3rd.
Re: More 727 trans problems from dum-dum [Re: CMcAllister] #2638497
03/29/19 02:36 PM
03/29/19 02:36 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
I am going to remove the VB and start with a front clutch air check at 150 and 40 psi to simulate R and 3rd under the assumption that if 1&2 hold so well I must have some line pressure in D and more in R. If it’s the piston seal I’m thinking I might hear engagement at high psi but disengagement will be almost instant instead of a quick sigh and at low pressure I’ll get no thud just air rushing.
If it seems to hold at both psi and not leak more than it should then I will dig in to the valve body and look for a backward piston or missing check ball. I stayed up late studying my trans books- I think I sorta have a handle on the trans circuit operations. I need to study up on valve body operation. I think the selector& throttle pressure are working and the governor vs line pressure is properly controlling the upshifts in D, at least until it needs to go to 3rd.
I never had a high stall converter before or built an auto before so I am not sure if it is sort of selecting D then slipping or what, but a lack of front clutch apply would seem to be a good candidate for my troubles. I remember doing the whole electrical tape and 15 mins in the freezer thing on the piston to try and get the seal to face down on the way in and I lubed it but did I air check it I dunno. I don’t remember it being particularly easy to install but I didn’t think I forced it…
In any case this is a new build with a handmade floor, firewall, console, etc so I was tempted to finish sealing and painting the bottom on a buddys lift but now I’m motivated to do it right- call this a successful mock up, take the body off to nicely detail and protect the underside, and have access from above to easily R&R the trans.
Thanks fellas for helping keep me moving forward in the right direction! I’ve been building this truck since May and despite some setbacks it’s really starting to come together now. The 512 is strong and the breakin oil and filter looked good, it steers, stops, and goes like a bat outta hell. Always more work to do.
Re: More 727 trans problems from dum-dum [Re: radar] #2638535
03/29/19 04:13 PM
03/29/19 04:13 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I gotta give you credit for doing it yourself! I've heard before that 727's are fairly simple, but obviously thats all relative. I personally hate pulling transmissions on my back, so for that reason alone, I would have it built for me to (hopefully) avoid any problems . Sounds like you're getting a handle on it, and you're learning a lot as you go. Hope you get it figured out soon.
2 kids and a dog
Re: More 727 trans problems from dum-dum [Re: TonyS451] #2640660
04/03/19 01:49 PM
04/03/19 01:49 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Gettin closer! I was bummed about pulling the trans out the bottom but I needed to finish the bottom and firewall of the cab anyway so I pulled the body off and the trans is right there. My new 727 seals & gaskets just came in the mail today too.
Doing more research on the front clutch piston made me remember what a pain in the butt it was and how I knew that it felt iffy going in but the only way to check it is pulling it back out and starting over trying to get it started.
Last time assembling the piston I wrapped in teflon tape then electrical tape to hold it facing down and put it in the freezer for 20 mins to try and keep it tucked tightly down. The teflon tape was to make the electrical tape come off clean. Then I smeared it with sticky blue transmission assembly grease and tried to push and shimmy it home.
Anticipating a re-do of that job I read back up online and in my books. I read about using sonnax slippery stick to glue the seal tight and facing down but nobody sells it around me. I did find door-ease for sale on amazon which was mentioned in another book so I got a stick of it.
Does anybody have any wisdom about doing this job better prepared this time? It’s a late 70’s 727 if that makes a difference-takes the thin seal I think? Have you had luck with the super sticky lube technique? Is door ease even a good idea to try?
Thanks!
Re: More 727 trans problems from dum-dum [Re: radar] #2640954
04/04/19 12:09 AM
04/04/19 12:09 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Ok I got her out and apart.
The air checks were all good except the front clutch which just blew air- no clutch apply sound.
I found a couple parts of a sealing ring in the pan- turns out they were off the snout behind the pump. My front clutch piston outer seal actually looked fine. It is flipped down, and not ripped or folded and needed a little pressure to go back home which I did twice inspecting between.
The kolene steels and red fibers saw some heat. The fibers are a little black around the edges and the frontmost steel (not the thick pressure plate) is noticably warped. I think I had some spares left over from the rebuild.
Could that steel sealing ring on the back of the pump be my culprit? The front clutch gets pressure from the reaction shaft right?
Thanks for the help fellas
Radar
Re: More 727 trans problems from dum-dum [Re: radar] #2640957
04/04/19 12:22 AM
04/04/19 12:22 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Here’s the half smoked clutch pack and the replacement parts I have on hand.
Re: More 727 trans problems from dum-dum [Re: radar] #2640975
04/04/19 03:10 AM
04/04/19 03:10 AM
A727Tflite Offline
A727Tflite  Offline
Those two rings are for the front clutch drum - looks like you found your problem.
Check the mating bore in the front clutch for damage.
The reaction shaft support looks a little worn below the seal, I would polish that up with 400 paper.
Make sure the new metal sealing ring turns easily within that groove - I would carefully take a fine file and make sure no burrs or edges exist in the groove and follow that with more paper polishing.
Make sure you have the ends locked after installation of the seal in the support.
Not sure what reference material you are using but the built front and rear clutches when placed on the pump can be pressure tested on the bench by using a rubber tipped blow gun and approx. 30 psi.
Just hit each round hole (not the pump attaching holes) around the pump - one is for the front, rear clutch, the others are converter in and out so ignore those.
Using high presssure hides issues liked nipped rubber seals and damaged seal rings.
Re: More 727 trans problems from dum-dum [Re: radar] #2640980
04/04/19 05:59 AM
04/04/19 05:59 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Absolutely found the problem, yes. The rings seal the drum feed. The thing is, there should be no way that any portion of the ring was found in the pan, unless the drum is now all ground to heck. The ring parts would need to be pretty small to fit between the support and drum. Could this have happened on installation?
Re: More 727 trans problems from dum-dum [Re: TRENDZ] #2641037
04/04/19 08:19 AM
04/04/19 08:19 AM
A727Tflite Offline
A727Tflite  Offline
By the way, you are pointing to the the fluid communication slot.
If you had the bottom seal ring there then you likely broke the seal on installation.
The seal goes in the groove just below your screwdriver tip.
Re: More 727 trans problems from dum-dum [Re: A727Tflite] #2641042
04/04/19 08:34 AM
04/04/19 08:34 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I'd check the rings grooves for being square. Set a new ring in the groove and hold it up to a light. The grooves should not be tapered. They should fit square to the ring. If they're tapered the reaction support is scrap. Also check the surface inside where the smaller steel rings ride. It should be smooth with no grooves where the rings seal.
Doug
Re: More 727 trans problems from dum-dum [Re: radar] #2641057
04/04/19 09:15 AM
04/04/19 09:15 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Is your clutch pack laid out the exact same way you disassembled it? If so it is wrong. Start with a steel on the bottom and end with a friction disc against the pressure plate.
Re: More 727 trans problems from dum-dum [Re: radar] #2641065
04/04/19 09:25 AM
04/04/19 09:25 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Radar
Yes you found your problem. If you did not do it cut off some 5/16 threaded rod and screw two short lengths in the case to help you align the pump as you install. Buy some regular trans assembly lube, very thick, coat the rings after you install, it helps keep them from hanging and breaking. Lot of guy now use the teflon type rings, they wear the drum less and seal better at high RPM's Make sure the grooves the rings go into on the pump are not damaged, 727's are prone to wear those grooves, and make sure the bushing in the drum is good. If the bushing is loose the drum will wobble at high rpm's and take out the rings.
https://www.ebay.com/itm/DR-TRANNY-...SSION-ASSEMBLY-LUBE-M465TG-/192450963604
http://coperacingtranscom.ipage.com/?product=727-teflon-sealing-ring-kit
Re: More 727 trans problems from dum-dum [Re: jwb123] #2641082
04/04/19 10:39 AM
04/04/19 10:39 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Thanks fellas!
The clutch pack did start with a steel- I accidently left it on the piston when I took the pack back out for the photo. And for sure I was pointing at the wrong groove in the pic! Long night...
Here’s some better pics of what’s going on here. The bore of the clutch shell actually looks really good to my untrained eye. You can see where the steels ride/seal but it doesn’t catch a fingernail and isn’t too wide so the endplay is probably ok too. This is the blue sticky assembly lube I have been using for the transmission. And the last two pics are of the damage to the sealing ring groove that had to have happened during installation. The pan had one little arc of sealing ring and a few crumbs. Most of the broken ring was still in the groove. If any had escaped during operation it would have chewed the crap out of the reaction shaft and drum inner bore- glad to not see $$ that. I think I can get away with touching up that ring groove so no burrs interfere with the ring floating freely.
I’m planning to replace the two warped cupped steels. The others are still dead flat with no bad burn marks. Also I’m replacing two fibers mostly because that’s how many spares I have. The fibers are a little black around the edges but not worn thin into the fiber material. Should I scuff the used ones with some scotchbrite? They don’t look real polished/glazed. When I first assembled this clutch pack it had 4 fibers and .045 clearance to the snap ring- when I pulled it the clearance was gone due to overheated cupped steels- one slightly and one noticably cupped/warped. I know I am on the tight side of acceptable clearance- I will re-check and verify it after I build it back up but I wonder if taking my pressure plate to the machine shop to have .020” skimmed off would be a great idea or a waste of time and money.
Re: More 727 trans problems from dum-dum [Re: radar] #2641116
04/04/19 11:37 AM
04/04/19 11:37 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
What thickness snap ring are you using? There are multiple thickness available. I believe .104" is the thickest. Drum ring surface looks OK. It the ring surface that the input shaft rings ride on inside the reaction shaft support. As I said check for ring groove tape with the ring in the groove. If its tapered it'll kill the ring in short order.
Doug
Re: More 727 trans problems from dum-dum [Re: dvw] #2641286
04/04/19 07:35 PM
04/04/19 07:35 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Doug
It’s a wave washer and it’s fifty thou thick. I have four steels & fibers in there and with some oil on everything there is basically no free play. My book says measure the clearance under the high section of the wave- I can probably fit a few more thou but .045” feeler guage slides in with no force. The fibers can move fairly freely but I think I want more clearance for the front clutch than the forward/rear right? A little room for the un-applied pack to spin freely but not so much that the seals could pop out? My book says with the wave washer I want .082”-.151”. Would milling .045” or .050” off the pressure plate be the easiest fix here so I don’t burn up my fibers when not in 3rd or R?
Thanks for the tip on ring groove squareness I’ll check that tonite!
Re: More 727 trans problems from dum-dum [Re: radar] #2641405
04/05/19 01:02 AM
04/05/19 01:02 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
The new rings fit very nicely in the reaction shaft on the back of the pump.
I did some measuring and it looks like if I sistered a steel under the pressure plate to make it .060 thicker then I could run 3 of the raybestos .065” stage-1 red clutches with .110 gap. I’m not doing that (!!) but if I had to drive it to work in the morning I’m thinking it’d work just fine- and might be a good way to be able to air check the piston before I get the clearance right to run the 4th fiber? With hopefully 500+ ft/lbs I’m going to get that 4th fiber in there! A machinist buddy said he could scrape 50 thou off the pressure plate nice and flat for me by tuesday. It’s up around .275” thick now. Maybe I should ask if he can machine a ledge around the edge and leave more meat in the center for heat dissipation and strength? Or am I overthinking it?
Can’t thank you all enough for the help with this 727. Next one I build will be easier!
