Spool engine mounts. C-body VS B-boy #264095
03/24/09 12:31 AM
03/24/09 12:31 AM
vancouver wa
mad car disease Offline OP
vancouver wa
Is there a difference between 71 C-body 400/440 engine spool mounts and 73/74 charger engine spool mounts .
We have a 71 C-body 440 going into a 73 charger and it sits two high. I was going to pull the engine mounts off a 73 Roadrunner with a 400 from a cordoba and see if they are different.
Re: Spool engine mounts. C-body VS B-boy [Re: mad car disease] #264096
03/24/09 01:21 AM
03/24/09 01:21 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Does the charger have a big block k-frame? If not, the motor will sit too high with any stock spool mounts.
Re: Spool engine mounts. C-body VS B-boy [Re: DaytonaTurbo] #264097
03/24/09 01:28 AM
03/24/09 01:28 AM
vancouver wa
vancouver wa
Different K-members?? The charger was a orig 400 car that the 440 is being put into. So since it is a 400 car shouldn't the 440 sit down lower?
Re: Spool engine mounts. C-body VS B-boy [Re: mad car disease] #264098
03/24/09 11:07 AM
03/24/09 11:07 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
All passenger car big block spool mounts that I have seen are the same. I don't believe c-bodies got spools until 74, though.
