Re: 14X6 Steel Wheels Rarity?
[Re: Droop69]
#2640599
04/03/19 11:36 AM
04/03/19 11:36 AM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Yep - they are hard to find! If you need a set, this looks like a good deal.
[Re: Morty426]
#2640632
04/03/19 12:43 PM
04/03/19 12:43 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
I think it is a good deal, but I also think the KH wheels are aftermarket Also, aftermarket rims will not have date codes that fit the production year of the car. They will have NO date codes.
[Re: m46rat]
#2640958
04/04/19 12:27 AM
04/04/19 12:27 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Both the Kelsey Hayes and Motor Wheel rims were used on 1970 and 1971 production cars. Kelsey Hayes rims NEVER have part numbers on them, Motor Wheel rims do, as long as they were not very early ones for 1970 production, when no rims came with part numbers. Saying that K.H. rims were aftermarket is to discount ALL the space saver rims which were only K.H. rims. I have never seen a KH wheel as original and I have a lot of rims. 68 Hemi 15x6 JK 70-71 390 Rallye Wheels (quite a few early ones with no PN) 70-71 450 Steel Wheels Then some various 14" wheels. Not one is a KH wheel. I believe you, I just find it odd I have not seen one.
[Re: Morty426]
#2641051
04/04/19 09:05 AM
04/04/19 09:05 AM
m46rat
Can't speak for the 68 rims, but the 390's and 450's were only made by Motor Wheel. The 14x6.0's, 14x5.5's and 14x5.0's. all rims that most guys don't give a crap about because they are for the most part, on base model cars, were made by both Motor Wheel and Kelsey Hayes. Motor Wheel rims have part numbers, Kelsey Hayes do not. Except for, as mentioned, early production ones from July and early August 1969.
[Re: m46rat]
#2641275
04/04/19 06:49 PM
04/04/19 06:49 PM
Morty426
Sacramento CA
Can't speak for the 68 rims, but the 390's and 450's were only made by Motor Wheel. The 14x6.0's, 14x5.5's and 14x5.0's. all rims that most guys don't give a crap about because they are for the most part, on base model cars, were made by both Motor Wheel and Kelsey Hayes. Motor Wheel rims have part numbers, Kelsey Hayes do not. Except for, as mentioned, early production ones from July and early August 1969. I have seen no part number wheels as late as 9/19/1969 Thanks for the info on the KH wheels.
[Re: Alaskan_TA]
#2644633
04/13/19 09:02 AM
04/13/19 09:02 AM
Posts: 1,328 VA
dragon slayer
VA
I have a pair (picture above) I would sell if they are needed.
Also, never say never as the following picture is a KH wheel with a part number. Looks like a 73 model.
[Re: 68_661charger]
#2645017
04/14/19 12:36 PM
04/14/19 12:36 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
What is good money on 1 14x6? Buying or selling? What date and condition? Pics? I’ve seen them $20-$350 ea.
68 Charger 70 Cuda
[Re: FC7cuda]
#2645051
04/14/19 02:36 PM
04/14/19 02:36 PM
Posts: 949 Indiana
68_661charger
Indiana
Ill have to check all that out. I dont see any markings near the valve stem but theres a ton of paint on it. Right now I only see a G and 11 near the lug holes and it seems it was originally white. Thanks for the info. So would you all say that the 4 nub 14x6 is harder to find than the 3 nub 14x6?
