How well do you like your Wilwood brakes
#2640446
04/02/19 10:22 PM
04/02/19 10:22 PM
Posts: 1,017 Howell, Michigan
Hemidavey
Howell, Michigan
Its time to order a front brake kit for my Hemi A body. Looking at kits from various companies. Wilwood has a 12.88 rotor, 6 piston caliper kits that is reasonably priced. Has anyone used this set up, or the 4 piston stuff, how well do they stop? Thanks
Re: How well do you like your Wilwood brakes
[Re: Hemidavey]
#2640469
04/02/19 11:19 PM
04/02/19 11:19 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Brakes are ok customer service is awful.
[Re: markz528]
#2640480
04/03/19 12:16 AM
04/03/19 12:16 AM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
They make a good product. Any of their stuff, properly sized will stop the car. But there is a big difference in weight between different versions and models. If you study their website, you can find a list of all the peices in each kit, the the weight of each peice.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: GoodysGotaCuda]
#2640512
04/03/19 08:50 AM
04/03/19 08:50 AM
Posts: 5,111 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Sticking with a front set you should be good with almost anything you order from them. Mine are the 4 piston...maybe Dynalites??? I picked them up used for the stock 10" drum spindles for the 72 Duster...that way it maintains the narrower track rather than going to the 73 up A body knuckles... Mine for my 65 B Body are still in the boxes new...Also purchased for the drum spindles...way too much work to do on the car before it's ready for them... I do know if you go with new rears there are some things that need to be modified to work correctly when using green bearing axles... The Wilwood plate that bolts to the housing for the caliper mounts and also handles the axle retention needs to have a groove cut in it for the snap ring on the green bearings and you'll need to remove the factory axle retention flange...I found if if the centerline of the caliper lines up perfect with the centerline of the rotor when bolted to the hub everything is lined up correctly...The rears I bought for the Duster were used and there were spacers between the caliper mount and the caliper...cutting a relief in the plate that bolts to the rear for the axle fixed the problem... When I ordered my rear axles I mentioned to Cass at Dr. Diff what I was using and he was all over it... He gave me a heads up about the alignment at the rear as I ordered the new axles with no retention plate... As mentioned earlier fronts were no problem...
...FAFO...
#2640530
04/03/19 09:20 AM
04/03/19 09:20 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My biggest problem is the lack of floating calipers. I get pretty decent pad knockback on the rear brakes. What is moving around back there? Can the axle clearance be tightened up a bit?
[Re: Hemidavey]
#2640578
04/03/19 10:52 AM
04/03/19 10:52 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
If you're considering Aerospace Components brakes, their customer service sucks too. I have their brakes on the front of my cuda...they work pretty good, but dealing w/ them for simple replacement/service parts is a pain in the rear.
[Re: feets]
#2640596
04/03/19 11:32 AM
04/03/19 11:32 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My biggest problem is the lack of floating calipers. I get pretty decent pad knockback on the rear brakes. What is moving around back there? Can the axle clearance be tightened up a bit? I’ve shaved the bearing retainer down a bit to try to limit the shafts axial movement. I’ve improved the knock back but it is not fixed. I’ve avoided added piston springs or a check valve to hydraulically bandaid it. It may be worth making flat bearing retainers to but it’ll take a little r&d to make sure I don’t over preload a green bearing.
[Re: Hemidavey]
#2649767
04/28/19 08:23 AM
04/28/19 08:23 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
You can get a hotter working brake pad with the willwood if you have trouble at high speeds.I have a pro street kit w/vented 11.75" 4 wheel with a hydraulic hand brake n extra caliper on the back for that.
