Driveshaft for D100 #2640328
04/02/19 06:21 PM
04/02/19 06:21 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Switching from a 9 1/4 to an 8 3/4. Am I looking at a driveshaft change or modification?
Abe Lincoln
Re: Driveshaft for D100 [Re: dart4forte] #2640372
04/02/19 08:15 PM
04/02/19 08:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Your current drive shaft is at the edge of being too short or too long. The difference is only about 3/4'" if I remember correctly. I can't remember which one was longer though...There should be enough clearance in the drive shaft length to accommodate the difference between the two rear ends.
Of course I was assuming you have the same size rear joints. If you don't, most auto parts stores have conversion u joints to handle the u joint issue. Gene
Re: Driveshaft for D100 [Re: dart4forte] #2640375
04/02/19 08:18 PM
04/02/19 08:18 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi dart, the 9 1/4 has a centerline of axle shaft to center of rear universal of 11.69" . and the 8 3/4 has a centerline measurement of 12.35" . .66 difference. what is your driveshaft to trans boot seal distance ? check and measure it BEFORE you take things apart. ronnie drive
Re: Driveshaft for D100 [Re: 1969ronnie] #2640767
04/03/19 06:14 PM
04/03/19 06:14 PM
Guitar Jones Offline
Most vehicles have plenty of spline length and engagement depth to accommodate that difference going the other way. You may need to have your shaft shortened though I was able to move my trans rearward 1.25" when I did the lock up conversion on my 92 without issue, just had to get the aftermarket output shaft seal without the dust boot.
