Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: cudaized] #263989
03/24/09 03:37 PM
03/24/09 03:37 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Once again, thanks ya'll.. Is there anything special about the fan clutch? Are the 22" shrouds available? All things being OEM, there's no reason my friend shouldn't be able to put things back. The only non-OEM factor is the radiator he has is a 22" with a 4-core. It may be just too thick, thus not enough clearance between the core and front face of the fan clutch....
Troy
Troy
Houston Mopar Connection Club
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: hemi68charger] #263990
03/24/09 03:45 PM
03/24/09 03:45 PM
USA
b54406barrel Offline
USA
Troy
I have no idea if they're the same but, my 6bbl, 22" rad RR doesn't have a clutch. It's a fixed fan and it has 7 blades, I believe. E bodies could certainly be different.
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: b54406barrel] #263991
03/24/09 04:59 PM
03/24/09 04:59 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
my 71 Challenger V-Code has a clutch fan and a 22 in rad. The 22in was standard in a 440/6 auto 3.23 rear.
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: THESHAKERPROJECT] #263992
03/25/09 10:09 AM
03/25/09 10:09 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: PAINT IT BLACK] #263993
03/25/09 10:16 AM
03/25/09 10:16 AM
Houston Texas
Houston Texas
Troy, I'm sending Hoss this info too, but here is a repro fan shroud.
http://amhightechauto.com/
Under "Heating and AC"
Part number 328
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: PAINT IT BLACK] #263994
03/25/09 10:48 AM
03/25/09 10:48 AM
Houston, Tx
Houston, Tx
Part number 328
Got it.. Told him Bill was top-notch..
Troy
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: hemi68charger] #263995
03/26/09 01:11 PM
03/26/09 01:11 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Besides the B & E, don't forget the C body '70 440-6 SFGTs, they also had a 22" std. I had one years ago with a 22" and 3.23 gears.
My '70 V code Bee still has it's 22" in place and does OK in the FL heat.
Has anyone come across a 22"er with 3.54/3.55 gears or were they 727/3.23 only? In other words, could the 26" be deleted when ordering a car with a lower gear?
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: B5 Bee] #263996
03/26/09 01:23 PM
03/26/09 01:23 PM
Houston, Tx
Houston, Tx
I haven't.. All big blocks that I know of that came with a auto/3.23/no a/c where standard 22"'s except for 426 Hemis, they all came with a 26"'er. Now, to get a 440 say, with 3.55's and a 22"? Wouldn't think so. I'm sure the engineers determined it was necessary. Probably void the warranty if it was done.......
Troy
Troy
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: hemi68charger] #263997
03/26/09 05:35 PM
03/26/09 05:35 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Troy
Yep, all the axle packages came with the 26" rad upgrade:
Cheers,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: hemi68charger] #263998
03/26/09 06:35 PM
03/26/09 06:35 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
My old 1970 440+6 Cuda was originally equipped with 3:55-Sure Grip and it got a 26.00 956 Rad
Re: Anyone with '71 v-code E-body 22" rad engine bay [Re: ScottSmith_Harms] #263999
03/26/09 10:24 PM
03/26/09 10:24 PM
Houston, Tx
Houston, Tx
exactly..........
Troy
