Anyone with '71 v-code E-body 22" rad engine bay
#263969
03/23/09 10:56 PM
03/23/09 10:56 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Anyone with '71 v-code E-body 22" rad engine bay pictures from original configurations? Helping a friend with his resto. and want to know exactly what it's supposed to look like.. I'm sure the upper tank inlet was like the '70 version driver's side off center..
Thanks..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Anyone with '71 v-code E-body 22" rad engine bay
[Re: Snoopy]
#263971
03/24/09 06:25 AM
03/24/09 06:25 AM
hemi68charger
Houston, Tx
Does your friends fender tag call out for a 22" radiator?
Nope.. it doesn't. It's an original v-code 727 3:23 car and the core support has never been modified.
[Re: hemi68charger]
#263972
03/24/09 09:44 AM
03/24/09 09:44 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
actually it would , if it doesn't have a 26 on it that would call out the 22" support .
[Re: JohnRR]
#263973
03/24/09 10:03 AM
03/24/09 10:03 AM
hemi68charger
Houston, Tx
cars with 22" radiators don't have a "22" stamped on their fender tags to the best of my recollection, only 26" cars.. So, by default, if there's no 26" call out, then it's a 22"..
[Re: shakerjoe]
#263975
03/24/09 10:48 AM
03/24/09 10:48 AM
hemi68charger
Houston, Tx
does the tag have N51 on it - max cooling package giving it the 26" rad, standard would be the 22" I'm pretty sure - Joe
Joe, I can't remember and the tag's been lost. Even with the N51 code, wouldn't there be a "26" on the top row? Again, the core support opening is the original one and it's definitely a 22 incher..
Troy
[Re: hemi68charger]
#263977
03/24/09 11:39 AM
03/24/09 11:39 AM
JohnRR
U.S.S.A.
[Re: shakerjoe]
#263978
03/24/09 11:40 AM
03/24/09 11:40 AM
JohnRR
U.S.S.A.
It would just have the 26 on it .
[Re: JohnRR]
#263982
03/24/09 11:48 AM
03/24/09 11:48 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I knew that's what you meant; I was agreeing with both of you.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#263983
03/24/09 11:52 AM
03/24/09 11:52 AM
DPelletier
Not a very good pic, but mine looks just like the one Scott posted; '70 V code with the 22" rad: Dave
1974 'Cuda
[Re: hemi68charger]
#263984
03/24/09 02:22 PM
03/24/09 02:22 PM
Posts: 2,309 South, FL
cudaized
South, FL
BS23V1B100103 22" Radiator
[Re: cudaized]
#263989
03/24/09 03:37 PM
03/24/09 03:37 PM
hemi68charger
Houston, Tx
Once again, thanks ya'll.. Is there anything special about the fan clutch? Are the 22" shrouds available? All things being OEM, there's no reason my friend shouldn't be able to put things back. The only non-OEM factor is the radiator he has is a 22" with a 4-core. It may be just too thick, thus not enough clearance between the core and front face of the fan clutch....
Troy
[Re: hemi68charger]
#263990
03/24/09 03:45 PM
03/24/09 03:45 PM
Posts: 3,054 USA
b54406barrel
USA
Troy
I have no idea if they're the same but, my 6bbl, 22" rad RR doesn't have a clutch. It's a fixed fan and it has 7 blades, I believe. E bodies could certainly be different.
[Re: PAINT IT BLACK]
#263994
03/25/09 10:48 AM
03/25/09 10:48 AM
hemi68charger
Houston, Tx
Troy, I'm sending Hoss this info too, but here is a repro fan shroud.
http://amhightechauto.com/
Under "Heating and AC"
Part number 328
Got it.. Told him Bill was top-notch..
[Re: B5 Bee]
#263996
03/26/09 01:23 PM
03/26/09 01:23 PM
hemi68charger
Houston, Tx
Has anyone come across a 22"er with 3.54/3.55 gears or were they 727/3.23 only? In other words, could the 26" be deleted when ordering a car with a lower gear?
I haven't.. All big blocks that I know of that came with a auto/3.23/no a/c where standard 22"'s except for 426 Hemis, they all came with a 26"'er. Now, to get a 440 say, with 3.55's and a 22"? Wouldn't think so. I'm sure the engineers determined it was necessary. Probably void the warranty if it was done.......
Troy
[Re: hemi68charger]
#263997
03/26/09 05:35 PM
03/26/09 05:35 PM
DPelletier
Troy
Yep, all the axle packages came with the 26" rad upgrade:
Cheers, Dave
1974 'Cuda
[Re: hemi68charger]
#263998
03/26/09 06:35 PM
03/26/09 06:35 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
My old 1970 440+6 Cuda was originally equipped with 3:55-Sure Grip and it got a 26.00 956 Rad
[Re: ScottSmith_Harms]
#263999
03/26/09 10:24 PM
03/26/09 10:24 PM
hemi68charger
Houston, Tx
exactly..........
