05 300C gear change tuning question #2639670
04/01/19 01:11 PM
04/01/19 01:11 PM
Commerce, Michigan
EasyG Offline OP
EasyG  Offline OP
Commerce, Michigan
Sorry if this is in the wrong forum but I wasn't sure where else to post.
We have a 2005 300C that we are in the process of installing a 3.91 Getrag center section in with new axles and hubs. What kind of tuning problems am I going to run into once this is on the road and do any of the box tuners have the capabilities to make the needed changes for the ECU and trans controller to work correctly with this change?
Thanks!
Re: 05 300C gear change tuning question [Re: EasyG] #2639715
04/01/19 02:46 PM
04/01/19 02:46 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I don't think you'll need to make any changes necessarily. A tunes always great to make the best of it. I know on the trucks they get their speed input from a tone ring on the ring gear so it doesn't matter what gear you install, the speedo will still be correct, but I think the cars get it from the output on the trans? If so you'd need a tune to get the speedo working correctly. Now that I think about it, if the speedo is off and the rear wheels don't match the front through the ABS sensors it might give you problems. The Mopar 11 Chargers had that combo factory (5.7/NAG1/3.91's) btw
Re: 05 300C gear change tuning question [Re: EasyG] #2640538
04/03/19 09:32 AM
04/03/19 09:32 AM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
No cars, and trucks with 4 wheel ABS or ESP get vehicle speed from the 4 tone wheels through the ABS/ESP module. You will not notice a difference on the speedometer unless you change tire rolling diameter. The only thing that may happen is the computer realizes your turning more RPM than it would like to see for a given speed and think there is a problem inside the trans. But I believe the 580 has input and output shaft speed sensors that would prevent this from being an issue.
