Ammeter to voltmeter
#2638974
03/30/19 08:55 PM
03/30/19 08:55 PM
Posts: 1,487 STL
cdstl
STL
I just got my Cuda's standard dash back from Instrument Specialties. Looks good. I had them convert the ammeter to a voltmeter.
So, now how do I hook it up?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Ammeter to voltmeter
[Re: cdstl]
#2638997
03/30/19 10:06 PM
03/30/19 10:06 PM
RapidRobert
neg to ground. positive to switched 12V, not sure where the best pickup point would be, maybe a switched circuit in the fuse box. EDIT or maybe the blue wire ign1 circuit as that is what the "system" is seeing at any point in time.
[Re: PhillyRag]
#2639053
03/31/19 02:57 AM
03/31/19 02:57 AM
Posts: 7,664 IN
ahy
IN
Now you have a Voltmeter: Great for monitoring Alt./V-reg operation. But Now how do you monitor battery state while operating car: Charged-Charging-DisCharging? If the voltmeter is up it is charging. 13.5-14.5 volts is good or you can tell visually with some experience if no numbers (like mine). If voltage is down it is not. I spotted a failing alternator - no charge - by occasional unusual fluctuations in the voltage. I hooked mine to the 12 volt feed used to power the instrument panel... it is switched and works fine.
[Re: PhillyRag]
#2639077
03/31/19 08:21 AM
03/31/19 08:21 AM
Posts: 1,487 STL
cdstl
STL
Now you have a Voltmeter: Great for monitoring Alt./V-reg operation. But Now how do you monitor battery state while operating car: Charged-Charging-DisCharging? I also eliminated a fire hazard. Gonna post a picture soon. I was gonna give IS a call, but it's the weekend. Probably won't be able to get to it until next weekend anyway. Thanks
[Re: ahy]
#2639466
04/01/19 02:14 AM
04/01/19 02:14 AM
Posts: 1,755 Phila
PhillyRag
Phila
Now you have a Voltmeter: Great for monitoring Alt./V-reg operation. But Now how do you monitor battery state while operating car: Charged-Charging-DisCharging? If the voltmeter is up it is charging. 13.5-14.5 volts is good or you can tell visually with some experience if no numbers (like mine). If voltage is down it is not. I spotted a failing alternator - no charge - by occasional unusual fluctuations in the voltage. . While monitoring voltage is helpful; it's still only an Indirect means of monitoring state-of-battery. With a "healthy" battery & an alt. able to handle any system loads; the ammeter typically only sees a moderate amp load for a relatively short period: (minor recharge after a start)..
