Re: Magnum truck pan la 360?
[Re: Andrewh]
#2638868
03/30/19 03:10 PM
03/30/19 03:10 PM
RapidRobert
IIRC the pan fitment is the same but you use the mag gasket with the 5.2/5.9 & an LA gasket with a 360. Spend some time makeing sure the front/rear black seals are fitted dead on especially the front one & some pans (more of an aftermarket issue) have a shallower "halfmoon" & the flat ends of the front black seal may need to be shortened a bit & sometimes the side gaskets need to be "sectioned" so the bolt holes are dead on and the 4 corner mini pieces can need trimming.the thin rear black seal may be a bit too long & need sectioned then some good cement at that junction. As you know oil leaks are the cats' ass/worth the prep/trouble.
[Re: B1MAXX]
#2638869
03/30/19 03:12 PM
03/30/19 03:12 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
The LA timing cover has two one inch long extensions just before the timing cover gets to the pan rail. The Magnum timing covers do not have those, so the pan either needs to have them flattened or fill the voids with silicon etc. Consequently, the Magnum pan wont fit over those LA extensions without modification to clear them.
As mentioned above, its easier to use an LA pan on a Magnum, but you have to fill the 2 voids in some manner.
Here are a couple pictures of my LA pan and the one piece Magnum gasket & the 4 piece LA gasket. Notice how the blue Magnum gasket effectively hides the 2 gaps with the flaps of the gasket. It took me a while to figure that out.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
