Re: OPENING IN BACK OF HOOD SCOOP?
[Re: 540DUSTER]
#2637085
03/25/19 06:53 PM
03/25/19 06:53 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Trim the back of the scoop to fit the windshield nice. Fab an interior panel to seal to the carb plate or directly to the top of the carb. I wouldn't put any holes in it or leave it open. Defeats the purpose of the scoop or worse with air flowing over the top of the carb..
[Re: Locomotion]
#2637302
03/26/19 11:06 AM
03/26/19 11:06 AM
Posts: 16,513 On the run…
BloFish
On the run…
I did this to resolve turbulence issues.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2637317
03/26/19 11:36 AM
03/26/19 11:36 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Those old scoops that sit flat on the hood look cool, but they don't work very well. The Chrysler developed snorkel or boundary layer bleed off scoop is still the basic design today. The size and shape of the pressurized area above the top of the venturis is what matters. Look at the shape of some of the interior panels offered by the high end shops selling scoops.
[Re: 540DUSTER]
#2637343
03/26/19 12:44 PM
03/26/19 12:44 PM
Posts: 4,210 New York
polyspheric
New York
The opening must be smaller in cross-sectional than the area of the interior behind it. The faster the car the smaller the opening. The air horns should be in still air with as much velocity converted to pressure as possible. "or worse with air flowing over the top of the carb" is true.
Boffin Emeritus
[Re: polyspheric]
#2637353
03/26/19 01:05 PM
03/26/19 01:05 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The idea is to create an area of positive pressure feeding the engine. Having an area inside the scoop, sealed to the carb without a lot of turbulence, is the trick. I'm not an aerodynamic expert, and I haven't hired one. But I do try to pay attention to what the guys who have are doing. If you think turbulence is an issue, experimenting with air cleaners, stub stacks or some other way of straightening the airflow may pay off.
[Re: 540DUSTER]
#2637484
03/26/19 08:16 PM
03/26/19 08:16 PM
polyspheric
New York
There are formulas on http://www.landracing.com/forum/index.php/board,31.0.html to calculate the hood scoop opening size based on top speed etc.
Boffin Emeritus
[Re: A39Coronet]
#2637811
03/27/19 05:56 PM
03/27/19 05:56 PM
BradH
With a 5" hemi scoop, my carb to hood air pan slowed me down .015. I have ABA slips to prove it.
Do you race with an air filter, or is the carb exposed directly to the incoming air stream? What type of carb, and what MPH are you running? I'm asking because your results are just about the complete opposite of mine when testing with and without the air pan that seals the carb to the T/A-type hood scoop.
[Re: BradH]
#2638594
03/29/19 07:31 PM
03/29/19 07:31 PM
Posts: 1,113 Usa
A39Coronet
Usa
Do you race with an air filter, or is the carb exposed directly to the incoming air stream? What type of carb, and what MPH are you running? I'm asking because your results are just about the complete opposite of mine when testing with and without the air pan that seals the carb to the T/A-type hood scoop. No filter, 1050 dominator, 128mph. Was having issues with the hood trying to lift off the car because of the positive pressure in the scoop. Ran numbers using cfm demand at 6800 vs. volume of air for scoop and determined the seeled scoop was causing drag. Removed the pan and picked up, and hood lift issue ceased.
[Re: polyspheric]
#3178393
09/26/23 02:43 PM
09/26/23 02:43 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
There are formulas on http://www.landracing.com/forum/index.php/board,31.0.html to calculate the hood scoop opening size based on top speed etc. Maybe something to take into consideration but LSR scoop will be smaller than a drag race scoop. (doesn't matter if the LSR car is restricted at the beginning of a pass)
[Re: BloFish]
#3178489
09/26/23 10:15 PM
09/26/23 10:15 PM
Posts: 22,697 Bitopia
jcc
Bitopia
I did this to resolve turbulence issues. I cannot contest your hole drilling benefited your car. But how and what it did exactly to achieve that and whether it might actually on another's car do the same is unproven until tried and/or tested. What actually might be happening in your case it might be allowing high pressure air at base of windshield to flow into the rear of scoop and then slowing the air entering the front and thereby reducing turbulence AND increasing ambient air pressure the carb sees, only as a guess.
[Re: jcc]
#3178490
09/26/23 10:31 PM
09/26/23 10:31 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If your car picks up by putting holes in the scoop, the interior of the scoop is not finished correctly.
The idea is to increase the pressure of the air available to the carb or throttle body. How can it be pressurized after knocking holes in it? Turbulence is the problem. Interior panels done correctly can benefit that.
[Re: CMcAllister]
#3178506
09/26/23 11:41 PM
09/26/23 11:41 PM
jcc
Bitopia
At speed there is often a high-pressure air bubble at the base of the windshield. That is the basis of Nascar intakes and the typical open rear Vette type scoops. If the scoop shown here has benefitted from rear holes being added, it might be from the additional air from the rear and it's slowing down front entering air, which could mean less turbulent air also at a combined higher pressure. We also do not know for certain if the front air scoop entrance is below the boundary air separation or maybe only partly above it, which impacts the positive contribution of any possible rear entry air.
