dakota still dieimng randomly #2635749
03/22/19 11:42 PM
03/22/19 11:42 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
92 model v6,i did the wiggle test on the wiring today to no avail,then i had the lid off of the under hood relay/fuse box,the auto shutdown relay was warm to the touch,not burn your finger hot but warmer than i thought it should be,is that normal or should the relays be cool/room temp?,this was after a drive and warmup
my ladder of success is missing some rungs
Re: dakota still dieimng randomly [Re: rhad] #2635821
03/23/19 09:16 AM
03/23/19 09:16 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Clogged up sock filter at the bottom of the submerged fuel pump module made my 1995 Ram suddenly die, then would restart 30 minutes to an hour later.
Re: dakota still dieimng randomly [Re: 360view] #2637928
03/27/19 11:35 PM
03/27/19 11:35 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
cleaned the throttle body and IAC valve today,time will tell
Re: dakota still dieimng randomly [Re: rhad] #2637969
03/28/19 08:14 AM
03/28/19 08:14 AM
USA
3
360view Offline
360view  Offline
3
USA
If the insides of the EGR valve have corroded away so that gas flows in the manifold at idle, that will cause the engine to die at low RPM’s.
Re: dakota still dieimng randomly [Re: 360view] #2638027
03/28/19 11:04 AM
03/28/19 11:04 AM
Inland Northwest
GB5andGY8 Offline
GB5andGY8  Offline
Inland Northwest
iagree
Had a 4.0 V6 Nitro with intermittent dying problems at low engine rpm. These were finally solved by replacing the EGR valve.
